What grade bolt to use as shear pin on a old MF 12 square baler?
   / What grade bolt to use as shear pin on a old MF 12 square baler? #1
Birch Hill Farm
Bronze Member
Kentucky
International 444
I have an old MF 12 square baler and it keeps eating through grade 5 bolts even when there is almost no load on it they will shear. Is something out of adjustment or do I need a higher grade bolt? I can spin everything by hand when empty so I dont think anything is binding. Maybe dull knife?
   / What grade bolt to use as shear pin on a old MF 12 square baler? #2
What size bolt does that baler use? Are you tightening or just snugging it? Does the unthreaded shank of the bolt extend a safe distance beyond the shear zone? Shearings slowly egg the holes degrading the predictability of torque to shear. Gr 8 may actually do damage, but at least, would egg the holes more readily. I ask about tightening because without it you may have the bolt rocking a little which gives an impact.
larry
Its a 3/8 bolt and it is shearing in the threaded portion. I just snug the nut down when installing. When the bolts shear I have to hammer out the remaining part do to the shear point of the bolt bending over slightly. Almost like the hole is egg shaped.
   / What grade bolt to use as shear pin on a old MF 12 square baler? #4
Threads smear ... and the bolt is smaller and weaker there. -- Get a bolt long enuf that the unthreaded shank extends thru the shear zone as much as possible - at least 1/4". Tighten it fairly firmly ~ 20 or 25 ftlb. Use locktite on the theads so it wont back off.
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2015 Ford Explorer (A50324)
2015 Ford Explorer...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
2 Row Planter (A52128)
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
