What goes up - goes up!
   / What goes up - goes up! #1
jsnitz
Upstate NY
On my old Ford 1710, (2200 Hrs) the 770B FEL suddenly acted up. No matter if I moved the stick up or down, the bucket went up. /forums/images/graemlins/shocked.gif I finally killed the tractor and could very slowly ease the bucket down by jiggling the valve. When I started up again, it acted the same way. 10 minutes later I tried again and all is back to normal. Has happened twice now. /forums/images/graemlins/confused.gif Any idea what is causing?
   / What goes up - goes up! #2
Did you pay your gravity bill this month? /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
   / What goes up - goes up! #3
It's the valve. I like the gravity reply, are we taxed on that yet /forums/images/graemlins/smile.gif
   / What goes up - goes up! #4
I like the gravity of the situation. /forums/images/graemlins/smile.gif
My combine did that once - well, actually did that 5 times - it was the poppit valve (pressure relief valve) that was cracking & causing the oil to flow in an unusual path through the valve. Very odd crack in it, you couldn't see it - had the tech guy scratching his head for a while until we noticed the problem.
There won't be any direct relation to your tractor, but I'll guess there is some small ding in some metal seal or bad o-ring or some dirt in your valving & it is causing the problems. Most likely not too serious, but will need to be opened up & looked over.
--->Paul
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2015 ISUZU NRR 20FT BOX TRUCK (A51222)
2015 ISUZU NRR...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
2013 TIGER CAT 720E WHEEL FELLER BUNCHER (A51242)
2013 TIGER CAT...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
