What gear & park brake when hoeing?
   / What gear & park brake when hoeing? #1
RedDirt
Northern Idaho
Kubota BX23, Wards 16HP HST Garden Tractor, (previous) D2 Logging Cat
What is not mentioned in my operator's manual is what position to place the HST shifter and whether the parking brake should be on or off when operating the backhoe.
Logic would say transmission in neutral and parking brake on. But I want to use my hoe to push me down the trench line (bucket and stabilizers raised a bit, of course), so I've been hoeing in neutral and brake off.
What do you do?
   / What gear & park brake when hoeing? #2
I'd don't do hydro, but obviously Neutral is the correct gear. I always set my parkin gbrake and lower my front bucket to keep the tractor as rigid as possible. I don't move the tractor with the backhoe, I climb into the operators seat and move it like normal.
Andy
   / What gear & park brake when hoeing? #3
RedDirt said:
1*What is not mentioned in my operator's manual is what position to place the HST shifter and
2*whether the parking brake should be on or off when operating the backhoe.
3*Logic would say transmission in neutral and parking brake on.
4* But I want to use my hoe to push me down the trench line (bucket and stabilizers raised a bit, of course),
5**so I've been hoeing in neutral and brake off.
6*What do you do?
1*In gear
2*Brake on
3*Not with my bx 23 It don't.
If it's in neutral & you lift the stapleizers and bucket you are in for a wild ride down the hill if you're on a slope.
Riding backwards wildly down a hill on an uncontrollable tractor that I can't reach the steering wheel and controls on cause I'm facing rearward just hain't my cup of tea.
Safety says Tranny in gear Parking beak ON.
4*i simply use the treadle
petal.
5*Should be in gear brake on.
6*See above.
   / What gear & park brake when hoeing? #4
I think you would know if your tractor was going to take off on you on a slope and if for some reason your tractor starts to roll it isn't going to take off instantly, you will have plenty of time to
1* drop the bucket
2* drop the stabilizers
Doing either of these will stop a tractor if some operator did something as strange as you are thinking.:rolleyes:
   / What gear & park brake when hoeing? #5
Robert_in_NY said:
1*I think you would know if your tractor was going to take off on you on a slope and2* if for some reason your tractor starts to roll it isn't going to take off instantly, you will have plenty of time to
1* drop the bucket
*I know my BX 23 will take off rolling down hill when it's in Neutral and the brake is off at the same time.
So then why should I increase the chance of that occurring by placing it in Neutral unnecessarily?
2*Why focus on stopping it after it gets under way when you can prevent it from getting started in the first place?
== L B ==
   / What gear & park brake when hoeing? #6
This is an interesting question. Sure to get some interesting opinions.
Having a gear BH, it gets neutral and parking brake.
I don't know if the bh on a BX is powerful enough to toss around the tractor. On more powerful BH's you want to limit the un-intentional motion of the machine as much as possible. It's real easy to pull, push lift and toss my tractor around with the hoe. That reduces the digging effectiveness.
Having a hydro kubota grand L also, I know that in low range and parking brake on would probably be my choice. Purely theoretical as that machine does not have a hoe! But, it would seem to be more stable that way.
jb
   / What gear & park brake when hoeing? #7
I personally do not lock the brake as if I am using a 3pt backhoe where I have to hop on and off the backhoe and tractor everytime I want to move forward while digging a trench. I leave it so I can move it with the backhoe. All I do is reach up for the loader joystick, raise the loader, then while the bucket is still in the trench (but curled in) I lift the stabilizers just off the ground (amazing, my machines having rolled away at this stage yet), then while the bucket is still in the trench I use the backhoe to push the tractor forward. Once the boom is at full reach I drop the stabilizers, drop the loader and continue digging. I can do this much faster then I would to hop on and off every time.
If I had a standard TLB where all you do is spin around in the cab then it is a different story but if your working in mud getting on and off the tractor and backhoe is not the safest thing when your boots are covered in mud every time you walk across the ground.
As long as the bucket is in contact with the ground the tractor isn't going anywhere.
   / What gear & park brake when hoeing? #8
LBrown59 said:
*I know my BX 23 will take off rolling down hill when it's in neutral and the brake is off at the same time.
So then why should I increase the chance of that occurring by placing it in Neural unnecessarily?
== L B ==
Why did you change what you quoted me as saying?:confused:
   / What gear & park brake when hoeing? #9
What do you do?
Neutral and no p brake if on flat ground. Easier on the transmission and brakes if you want to move the tractor around with the hoe. Also this is with a TLB (tractor/loader/backhoe), not a tractor with a backhoe attachment.
I can't tell if you have a 3 pt hitch mounted or a sub frame mounted backhoe. I would personally think twice about moving the tractor around with a 3 pt hitch mounted hoe. Seems like a lot of forces on the hitch that it might not have been designed for, as well as adding extra load to the transmission/engine bolts.
   / What gear & park brake when hoeing? #10
X2:cool:
2011 WESTERN STAR 4900 (A53843)
2011 WESTERN STAR...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
2018 ASV Posi-Track RT120F (A47477)
2018 ASV...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
