What Ford tractor did the FARMTRAC 45 copy?????
   / What Ford tractor did the FARMTRAC 45 copy????? #1
MotoXer
Central Florida, USA
FarmTrac 45
Does ANYONE know the answer to this? Which model Ford tractor was the Farm Trac 45 copied after? I'm wondering if the loader brackets from a Ford 3910 will fit the Farm Trac 45... The Ford 3910 is too far away to compare or measure, I need some wisdom here.
Thanks, RUSS /forums/images/graemlins/confused.gif
   / What Ford tractor did the FARMTRAC 45 copy????? #2
the 3910 is more like the Farmtrac 60 but I am not sure on wether or not they use the same loader. But if I remember I can check at work
   / What Ford tractor did the FARMTRAC 45 copy????? #3
The frame of the FarmTrac 45 and 60's are the same---take the same loader mounting frames. The only difference between the two are the tire/wheel sizes , hp, and the FT 60 comes standard with dual remote hydraulics.
And yes, they are real similar to the Ford 3910.
The 3910 loader frames will probably work---depending on the loader model. You may need to do some minor mods.
dancce
I found out that the BushHog loader brackets are the same part # for the Farmtrac 45, 60 and Ford 3930 but not the same for the 3910...that's weird.
I think I'm going to just buy a KOYKER loader for my 45...I think they're pretty good loaders.
Thanks guys, RUSS
   / What Ford tractor did the FARMTRAC 45 copy????? #6
I believe the reason for different mounts, has to do with the different steering systems used. The Farm Tracs and the 3930 have the newer style hydrostatic steering and the 3910 used "power assist" steering with the side arms running parallel to the frame.
We regularly install the Koyker 210 loader on the FarmTrac 45's & 60's as well as the LongAgribusiness loader. Both are a nice fit, and about the same price.
dancce
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2019 CATERPILLAR 299D2 XHP SKIDSTEER (A51242)
2019 CATERPILLAR...
