jherrington
Hey guys, I recently "inherited" this tractor from my grandfather. It had sat for years without use, and I've got it running well after replacement of the fuel lines, new diesel(learned how to bleed the fuel lines during this process), patched the front flat tire, and cleaned the air filter. I need this tractor to cut 70 acres of pasture. The PTO arms lift without any weight, and will lift me, but when i put the bush hog on it, it will lift it only about 6 inches off the ground.
I looked in the Back axle to see if there was fluid in it, and there was minimal amounts, that i had to look hard to even see at the bottom.:ashamed: Would this have an effect on the lift arms not being able to lift the bush hog? Also, even though this might not affect the lift, but what fluid should go in there? what weight? thank you
