What fluid do I use for the transmission for my 53 super c
   / What fluid do I use for the transmission for my 53 super c #1
feleds
Bronze Member
Lisbon, Ohio
1953 Farmall super c
I read somewhere that I could use ATF or 30 at oil. Not sure what痴 in it now but it痴 low
   / What fluid do I use for the transmission for my 53 super c #2
80/140 gear oil for the trans. PTO is same reservoir as trans. 30wgt could be ran in hydraulics if you really wanted, but I run a hydro fluid in that. The thicker oil will quiet the gears a bit. ATF is WAY too thin. No need to use Hytran or equivalent on non T\A Tractors
Thankyou for your help. All I needed to know for now.
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
Pallet of Miscellaneous Heaters (A52384)
Pallet of...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Mitsubishi Mini Truck, 3cyl Gas Engine, 2WD (A52384)
Mitsubishi Mini...
2018 FORD F-150 (A53843)
2018 FORD F-150...
