What equipment to use?
   / What equipment to use? #1
DTCOOPER
Bronze Member
Bullard, TX
02 CIH D33
A friend works for a local equipment rental company, so I am getting "hooked up" on which ever I use..
I have to dig 350' of 16-18" deep trench, and dig a small gold fish pond.
Which machine would I be best using? (time, ease of use, etc)
Mini track-excavator?
Small backhoe with front loader bucket?
I have the D33 but I have a hard time digging trench with the loader bucket and box blade.. /forums/images/graemlins/grin.gif
What say the masses ?
   / What equipment to use? #2
For the trench, I would recommend a trencher. IMO you'll be done a lot faster walking behind a big Vermeer, than repostioning a BH for 350'. Use a BH for the pond.
DH,
There in lies the problem.. I can only get one piece of equipment.. What would your suggestion be, knowing that ?
Thanks as always,
   / What equipment to use? #4
I had to dig a 4' deep by 6' wide trench, it was only about 45' long, but I used a mini-excavator. I started after lunch and was done before dinner and I took a break. I figure the same job would have taken a couple full weekends of work with the Great Bend backhoe on the back of the Kubota. The 2 great big HUGE advantages of the mini-excavator is the ability to move the machine at will and reposition it constantly combined with the much longer reach, a TLB can be moved but not in the same way with the same speed.
A trencher is great for a small narrow trench to bury cable, drainage pipe, etc, if you are doing something like that, then a trencher might be a better choice. But if you are making a trench for the purposes of leaving an open sloped sided trench then the mini-excavator is the ticket. So I guess it totally depends on the trench you are digging as to the best tool for the project.
For digging the goldfish pond the excavator will be the best choice.
   / What equipment to use? #5
Given the choice between TLB and excavator, I would use the excavator.
   / What equipment to use? #6
The excavator.
   / What equipment to use? #7
excavator and a can of ground marking paint.
   / What equipment to use? #9
When I had my new well put in the guy used a Ditch Witch that had a backhoe and scrapper blade on the front and a trencher on the rear. I have seen these for rent in Michigan. The unit is the size of a medium sized tractor. The guy made short work of the trench and had to dig a good sized hole near the house where the water pipe accessed the basement. He used the blade to cover the trench and hole when he was done.
   / What equipment to use? #10
I'd have to say the excavator will save you time, anything that is designed for a specific purpose will always do a job better than a "multi-pupose" tool. An excavator does one thing, it excavates.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
AEROQUIP PROOF TESTER (A53843)
AEROQUIP PROOF...
2023 Yamaha R Max XTR  (A52384)
2023 Yamaha R Max...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2012 Freightliner M2 106 Braun Ambulance (A51692)
2012 Freightliner...
