What engine to power water pump??
   / What engine to power water pump?? #1
northcreek2624
Lake View,N.Y.(WNY)
KIOTI DK40(2002)) Jacobsen 628D AWD Turfcat
Hi folks!
I'm looking for a power plant to turn a 4"x3" centrifugal water pump,the manuf.suggest a 25-40 hp engine that can operate comfortably at 2600 rpm.
I'd like to go diesel but,have not ruled out gas.A compact tractor engine would be great if the prices were not in the stratosphere.
Can anyone think of any compact car diesel engines that would work,I guess more hp wouldn't hurt.Also is there an aftermarket governor unit that can be added to an engine.
This may be a tall order but,I'm trying to help my son who has limited $$ to spend on this venture.
Thanks for looking and hopefully your ideas.....Mike.
   / What engine to power water pump?? #2
Mike;
Try looking at the Wisconsin V4 line up. They have them from 30 to 65 hp. Integral governors, air cooled, proven over time and always on ebay.
Sim
Thanks Sim,I had forgotten about the old V4,at one time you saw them everywhere.........thanks,MIKE.
   / What engine to power water pump?? #4
Look at surpluscenter.com.. they sell lots of stationary gas and diesel engines.. as well as some perkins power units with the 'wide open' governor throttle sets like for generators or welders.. etc.
Soundguy
   / What engine to power water pump?? #5
A friend just bought a very nice saw mill that is powered by a VW engine. I think they are in the right hp range, air cooled, easy to work on and should be cheap to find.
What will you be using that much pump for?
MarkV
Thanks Soundguy,I had checked them earlier they had a Perkins that would have been perfect but,are no longer available......Mike.
Thanks Mark,Those VW's are getting a little scarce,I'm leaning towards a 24hp Honda V-twin,reliable and pretty reasonable too.
My son co-owns a MX track and we are upgrading the watering truck.We have a 5 ton army truck(old truck was 2wd),we have placed a 6000 gal tank on it and want to increase the pump from 3" to 4" intake,it's kinda like Monster Garage......Mike.
   / What engine to power water pump?? #8
what GPM and pressure are you trying for. I have a supercross track and water it with a 2000 gallon tank. i use a 2hp electric motor (about 125 GPM). i pull the tank behind my kubota. how are you going to control the water flow?
www.ridemudroad.com
Jeff,We have two national caliber tracks on 130 acres of naturally rugged land.We run practice,race,school,member and special events.
Our water truck is modeled somewhat like the one used at Steel City.The spray nozzles are controlled by air valves...thanks,Mike.
www.area51motocross.com/
   / What engine to power water pump?? #10
Deutz makes nice small air cooled diesels.
My preference would be for a Honda air cooled.
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
Original Case Dealership Cast Iron " OLD ABE" Eagle Statue
Original Case...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
198367 (A51243)
198367 (A51243)
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
