What does Case Warranty Cover?
   / What does Case Warranty Cover? #1
rebelback
Bronze Member
South Arkansas
2010 Case Farmall 45 HST
I have a Case IH Farmall 45 I purchased earlier this year. The other day I managed to somehow run over a little tree that popped back up, busted my grille from my hood and kind of bent everything out of shape. I backed out of the situation and got it back to the house. I popped the hood and noticed there was a bolt missing from one of the holes that holds the grille to the the hood. I'm not sure how a metal bolt came out of a plastic hood without breaking the hole, but it did. Anyways, I dropped the hood back down and everything was still off center. The hood won't reopen now either. I also discovered the parking brake will not engage now. I'm assuming the answer is no, but will Case cover these repairs? At least to the parking brake?
   / What does Case Warranty Cover? #2
Doubtful anything will be warranted on your hood. It was damaged from "abuse". The PB might be covered. It could just need an adjustment by loosening the two bolts (13mm socket) that hold the pawl bracket. Then push the bracket towards the rear of the tractor and tighten bolts again.
Did your grille ever align with your headlights properly? Most never have,it's a design issue.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2016 FREIGHTLINER...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2011 DOOSAN G25 GENERATOR (A52472)
2011 DOOSAN G25...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
