What does &amp mean?
   / What does &amp mean? #1
mars1952
Western North Carolina
1999 John Deere 4300 12/12 sync-reverse
Hi:
I have been lurking for a while, trying to read through the 1,000,000 plus threads. The abbreviation &amp keeps showing up and I can't figure out what it means.
I have a bunch of projects planned and I will post pictures as they progress. I have a 130-acre farm and have completed many projects with my old Dayton 250 amp stick welder. I have had the Dayton welder for 30 years and it was used when I got it. Reading this forum has inspired me to try more complex projects that I had dreamed up but didn't quite have the know how to pull off and there are many things discussed here that I never would of thought of and didn't know I need until now ;-).
Current project: FEL bucket tooth bar
Next project: FEL Thumb
Future projects (If I live long enough!):
Self Leveling FEL for small CUT
Bobcat type Quicktach for my small CUT
Tag along and Trailer Gooseneck hitch for 3PH
3PH bale spear
Pan scraper
Root Bucket
Rock Bucket
Loose Material Bucket for Backhoe
Root Claw for Backhoe
Top and Tilt
FOPS with canopy
Draw bar hitch road grader
Top Soil Screen
Special Trailer for a Ranger UTV (To carry and be pulled by the Ranger)
These should keep me busy for a while ;-)
To facilitate these projects I just bought and have not yet set up a new Millermatic 251 mig welder with a gas setup and a new Miller Spectrum 625 plasma cutter. I have been using the above mentioned Dayton welder and a small portable acetylene torch and a Jet 7” capacity liquid cooled metal cutting bandsaw.
Marshall
   / What does &amp mean? #2
& is the HTML character code for ampersand.
   / What does &amp mean? #3
Thanks Dave, and thanks Mars, I had been meaning to ask that question.
   / What does &amp mean? #4
Sounds like too many implements for just one tractor, maybe you need to start looking for another one, or two, or...
BTW, welcome to TBN.
   / What does &amp mean? #5
Ignore it. Or read it simply as an ampersand (&)
It's an HTML code that wasn't properly converted for display and doesn't really have any bearing on the meaning of the post. I suspect that you are seeing it mostly in older posts that have gone through an archival/conversion process to a new format.
Reply
Hi Tom & Dave:
Thanks, I have one less thing to be confused about now.
Marshall
   / What does &amp mean? #8
Geez, I thought I knew what it stood for, but now I'm confused. Whats ampersand? Whats the symbol for quicksand? Do all sands have a symbol?
   / What does &amp mean? #9
Dirt, ampersand is that material found stuck to the very tips of tractor radiator fan blades. It is very fine and can't be graded. :)
   / What does &amp mean? #10
Is it kind of yellow in color? Oh no, that would be ambersand I guess.
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
