What does a battery's cold cranking amps tell me?
   / What does a battery's cold cranking amps tell me? #1
oakford4
Bronze Member
Hello,
I've noticed that the several garden tractors I am comparing have different CCA (cold-cranking amps) values for the same 12V power. What can this tell me in comparing, perhaps, the power differences between different garden tractors? For example, the three tractors I am looking at have substantially different CCA values:
Cub Cadet GT2554: 12V battery w/ 275 CCA
John Deere X340: 12 V battery w/ 160 CCA
Simplicity Conquest: 12 V battery w/ 340 CCA
Any input is appreciated. Thanks.
   / What does a battery's cold cranking amps tell me? #2
To quote from this site "CCA is the discharge load in amps which a battery can sustain for 30 seconds at 0 degrees F. and not fall below 1.2 volts per cell (7.2V on 12V battery). This battery rating measures a burst of energy that a car needs to start on a cold morning." I think that's as good an explanation as you'll find.
Actually, I think it tells you very little in the way of useful information. A bigger engine with higher compression might require more battery power or a more powerful starter to get going. The higher CCA battery, having greater capacity, might last longer. But whether the one with the highest capacity battery is the most powerful engine is not guaranteed. Maybe one with a smaller engine is just giving you a better battery.;)
Just my opinion, only, of course since I'm no engineer or electrician.
   / What does a battery's cold cranking amps tell me? #3
Bird's description is very good. The only thing I would add is don't compare engines by battery size. Compare engines by HP rating. Different manufacturers using the same engine may use different battery sizes for a couple of reasons. Size constraints and quality could be a couple of reasons.
   / What does a battery's cold cranking amps tell me? #4
Bird's description is accurate, but for the most part CCA is an advertising tool. Basically, the CCA rating of your battery should equal 3 X engine displacement as a general rule of thumb.
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
LINDE WELDER (A53843)
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
