What do you make of this?
/ What do you make of this? #1
AMR
Woodbury, CT
B3030
I turned my B3030 transformer this weekend from TLB to lime spreader, gave her a good bath, and then put on my 60" MMM for its first run of the season.
The mower was stored in the garage all winter, nice and dry, pretty stable temperature. When I greased the right hand spindle the grease pushed out a whole bunch of fluid, both on the top of the deck and out the bottom, it was white with the consistency of water. Can anyone guess where that came from? It was enough to take let's say three paper towels to clean up.
The deck was new last October, I mowed maybe 6 times with it and put it away for the winter. I did give it a quick bath before the winter, nothing more than a garden hose with a nossle and I am sure that I greased it after that bath.
In any event, I greased her up good and then ran it for about an hour. Sounded fine and cut like a champ.
/ What do you make of this? #2
Could be just a little condensation from temperature changes.
/ What do you make of this? #3
I've had water creep into grease boots and the like from using a pressure washer. I even had a tranny fail on a mower that I used nothing more than a water hose on and the mechanic told me water had gotten in there. Nowadays I limit my use of water to clean up my mower deck or the tractor for that matter and just blow the dirt off with the air compressor. I still give them a bath occasionally.. but I try not to direct water onto any place where gears/pulleys or anything with a grease fitting is.
New/Unused Landhonor Power Rake (A65583)
New/Unused...
New/Unused 25ftX33ft Double Garage Metal Shed (A65583)
New/Unused...
WOODS TS1680 - 14' ROTARY MOWER, 3PT (A64278)
WOODS TS1680 - 14'...
Landhonor Quick Attach Landscape Rake (A66408)
Landhonor Quick...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A63276)
2014 MACK ELITE...
Ford Pickup Truck Bed (A64556)
Ford Pickup Truck...
