jimgerken
Veteran Member
With LP costs rising every year, I am getting more interested in buying or building a Corn-fired boiler to be installed in the yard somewhere, fed from a bulk storage bin next to it, and running the heat thru buried insulated water lines (anti-freeze protected) to heat exchangers in the buildings I wish to heat. For instance in the house, it needs only a radiator of sorts for the hot water to flow thru and the air in the cold air return of the present forced air system to pick up the heat. And in my shop I have hydronic radiant floor heat, so it will be even easier to utilize the hot water there. I read last nite that a gallon of LP contains approx 100,000 BTU of heat, and a bushel of dry shelled corn contains approx 500,000 BTU. It is interesting to note that the gallon of LP and the bushel of corn cost about the same in my region right now. But, in other parts of the US, people are paying up to three times as much for LP as I am. It seems that there are also govt grants available to some purchasers of energy products using renewable energy sources, corn soves and boilers included. I think it is economical to install the boiler even without the grants, 'cause according to my math I'd get paid back in about four years. The grants make it sweeter, if they actually exist. And possibly home-building some or all of the system including the boiler would make it seem almost like free energy. I guess it seems attractive since I live in the country surrounded by cornfields, my heating bills rise every year, I can see the bills would be 1/5 as high using corn only, or possibly something like 1/3 as much if it was used only to suppliment my current needs.
Does anyone have info that can help my research into either commercial boilers OR homebuilt ideas? Thanks in advance!
