what do the adjusting screw on a cat 416b loader back hoe adjust
   / what do the adjusting screw on a cat 416b loader back hoe adjust #1
bobster43
jacksonville fl.
cat 416b
i have a cat 416 b backhoe and having low pressure on the backhoe controls have to keep stablizer lever engaged 2 get enough power 2 get swing 2 work other controls have reduced power but work there are set screws by the operating rods tried adusting and pressure didn't change it has a closed center system with a variable flow pumpfront loader gets 3000 psi operating at full lift
so i think pump is ok any one have experience with cat systems tx bobster 43
2019 Dodge Durango (A53421)
2019 Dodge Durango...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light (A52377)
2019 Allmand Bros...
2011 Caterpillar 299C Two Speed Compact Track Loader Skid Steer (A52377)
2011 Caterpillar...
2016Takeuchi TL8 (A47477)
2016Takeuchi TL8...
