What do I have and how do I fix it!!
/ What do I have and how do I fix it!! #1
fishnfowlr
Hattiesburg, MS
Zen Noh 20hp, 3 stroke diesel
I know it's a strange title, but I was just given a Zen Noh tractor from my brother. I searched threads on this site and some say it's a Kubota and others say it's a Yanmar. That's no issue either way as long as it's running. I went to pick it up and the left brake pedal had no give. Stiff!! Started pulling the tractor out and the left tire was locked solid. Couldn't force it to turn. I noticed the brake pedal being stiff and took a hammer and tapped the shaft that comes off the left brake housing. It never budged. Before I dissabsemble the left brake housing, I was hoping to get some feedback from you all as to what I should be looking for and possible solutions to a "frozen" brake. Not sure of the model. Never did see an ID tag other than a sticker under the hood with all writing in Japanese. My brother said it's a 20hp, 3 cylinder diesel and it looks to be in good shape. He parked it 2 years ago when it wouldn't crank. I'll deal with that part later. First, just trying to get it to roll so I can load it on a trailer. Any ideas what might cause the brake to lock up and solutions to fix it? Thanks all, Brad
/ What do I have and how do I fix it!! #2
zen noh is a farming coop name. was common to get custom branded tractors when they ordered them... so yeah.. COULD be a yamar.. etc.. etc.
post pics.
hmm.. stuck brake pedal.. stuck wheel..
I'd look to see if there is a bushing the shaft goes thru and lube it with a penetrant oil like pb blaster, adn then use a rubber hammer to beat on it.. etc..
ps.. most mechanical, drum, self energizing tractor brakes work the least, in reverse.
also.. if it has an adjuster.. like a common star wheel.. just back it off all the way...
post pics.. they will help....
2022 EZ-GO ELITE...
2000 Kubota KX121-3ST Mini Excavator (A61572)
2000 Kubota...
2023 NISSAN ALTIMA SEDAN (A59912)
2023 NISSAN ALTIMA...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
Caterpillar D4D Tractor Service Manuals (A63117)
Caterpillar D4D...
Challenger MT400 and MT600 series tractor parts manuals (A63117)
Challenger MT400...
