What do I do next
   / What do I do next #1
PuJo
Central Louisiana
2015 RX6620PS
Morning All.
I have recently brush cut about 15 acres that hasn't been cut in about 20 years.
There were many trees that were about 2-3 inches and larger in diameter. Now that the area is cut, I am left with thousands of small cut trees and branches.
Way too much to pick up by hand. What is the best way to clear this up?
Thanks,
PuJo
   / What do I do next #2
A grapple would be my choice. Are there stumps left above the ground? If you can drive over it with a tractor, I guess you could use a box blade or rake, as long as it won't get snagged on stumps. But it would be slow. Or just let it rot over time, perhaps spraying it regularly with herbicide to keep it clear until you can bush hog it and chop it up . Guess it depends on what you want to do with the area, how big a hurry you're in, and your budget.
Sent from my iPad using TractorByNet
   / What do I do next
No many stumps left. Most of them are either cut at or below ground level.
I have plenty time, just cleaning the property, no plans as of yet.
I do not have a grapple, so maybe just the box blade.
Thanks,
-PuJo
   / What do I do next #4
Is it in an area where you could have a controlled burn in the spring? Would get rid of the brush weeds and possibly the stumps as well as put nitrogen back in the soil.
   / What do I do next #5
Push them into piles with front end loader or back blade. When you get all you can in one pile, burn it and move to the next area.
   / What do I do next
I plan to burn them in the spring.
It's way off the beaten pass, but I will contact the local fire dept in advance.
I guess using the loader, and blade would do the trick, just going to take a while...
But that's half the fun isn't it??
I guess my overall goal is to get the area clean, and get the grass (not weeds) to grow.
Thanks,
-PuJo
   / What do I do next #7
Buy a Ratchet Rake for your bucket from the T-B-N store.
Ratchet Rake on your bucket is really effective at piling timber debris, prying out <3" stumps and light grading after brush has been removed. Much, much more effective than a 3-Pt. mounted Rear Blade or Landscape Rake.
I would favor burning piled brush.
VIDEO LINK: https://www.youtube.com/results?search_query=RATCHET+RAKE
   / What do I do next
Ratchet Rake is really effective at piling timber debris, prying out <3" stumps and light grading after brush has been removed. Much, much more effective than a Rear Blade or Landscape Rake.
Cool, I have a tooth bar with 4" teeth that was installed at the dealer. It only has one set of teeth but I think I can get it to work like the video.
Thanks!
-PuJo
   / What do I do next #9
No, you cannot.
Tooth Bar is not a substitute for a Ratchet Rake.
For $400 buy a Ratchet Rake. Fifteen acres contains a lot of debris. You will be glad you disgorged for the Ratchet Rake.
   / What do I do next
Ok, thanks for the insight.
I am saving to purchase a set of 12-14 foot disc at the moment. It will have to wait till I get the disc first.
Thanks,
-PuJo
UNUSED JCT HD HYD BACKHOE ARM (A51248)
UNUSED JCT HD HYD...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51248)
KNOW BEFORE YOU...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
RoGator RG1100C (A53473)
RoGator RG1100C...
