What did this to my tree?
   / What did this to my tree? #1
rangerfredbob
Veteran Member
Dayton, Oregon
Kubota L260
This is on a weeping willow, there's a trail leading from the creek that's 40' from the tree through the grass to this. Only the bark is disturbed, the underlying wood is barely even scratched.
There's been beavers in this area but I haven't seen anything from them in a couple years, I got a nutria a few years ago so that wouldn't surprise me, I've seen skunks and opossums and racoon tracks. Depending on what it likely is will slightly change my plan of attack, will likely involve a Harbor Freight driveway alarm. Tomorrow I'll wrap it with some hardware cloth or whatever I find in my shed to protect from further damage.
I have a feeling it hasn't done anything for a month or so since the water level FINALLY dropped far enough that I can mow to this tree which is why I haven't noticed until today.
How lethal is this to the tree? It's maybe 10" diameter and around 5 years old, being a willow it should be fairly resilient but that's a lot of damage, any good way to treat it to help it along?
You might also notice I have a red breasted sap sucker problem too, but that's a whole other thing that isn't as pressing as whatever jerk did this...
   / What did this to my tree? #2
I found a similar scar on one of my trees. I was told it was a buck deer that did it.
Bruce
   / What did this to my tree? #3
Male deer scrape, marking territory.
at ground level? normally that starts about a foot up and would have at least some scars in the wood, not just bark damage, I only saw one piece of bark on the ground. I have another weeping willow over a hundred yards from this one that I think does have buck deer damage, but not near this extreme and starts about a foot off the ground.
Until I posted I didn't realize the picture wasn't great, I'll try to get something better tomorrow...
   / What did this to my tree? #5
I have another weeping willow a hundred yards from this one that I think does have buck deer damage.
Male deer (with unusually short legs) scrape, marking territory.
Leave my does alone!
   / What did this to my tree? #7
Not saying for sure, but google "porcupine tree damage image" and see what you think. I don't think it looks anything like any deer rub (not scrape) I've ever seen. Notice the claw marks at the upper right portion.
   / What did this to my tree? #8
I would guess that damage is from a porcupine
   / What did this to my tree? #9
That doesn't look like porcupine damage to me. They don't pull the bark off in strips the way that it was done up on the top.
I see similar damage from moose, but it wouldn't start at ground level.
It looks more to me like something rubbed against it; if the tree was underwater, perhaps a floating log did it?
   / What did this to my tree? #10
I've never seen bark damage that went completely to the ground. Except for mice and rabbits and your damage isn't from either of those two. Beaver killed my giant weeping willow. It didn't look like that. Deer, moose, elk will scruff the bark but not remove it like that. Porcupines go way up my pine trees - up on top - to chew on the more tender parts of the tree. They also chewed the wood handles of my wheelbarrow.
Where did all the bark go - ???
A trail cam might tell the story.
Check with a florist shop or arbor specialist. There are special products that can be painted on tree scars before you wrap that area.
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
43029 (A51691)
43029 (A51691)
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
20" Sea Container (A47384)
20" Sea Container...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2012 Ford F-250 Pickup Truck (A52377)
2012 Ford F-250...
