What cutter to use on Bullrush/Tules?
   / What cutter to use on Bullrush/Tules? #1
trentay
Bronze Member
Our ponds on the duckclub are just drying up now and was hoping to get some advice on the best way to open up some of the ponds that are getting choked out with bullrush/tules. What are the different cutting attachments anyone has used to mow these things down with good effect? Looking for something to use behind a compact tractor 20 to 30 hp that can also be used to mow the grass on the roadways.
Anyone tried a sickle bar mower for this? Trying to find the least expensive cutter possible.
   / What cutter to use on Bullrush/Tules? #2
Trentay:
If the ponds are dry enough to drive the tractor on them without getting stuck, a rotary brush cutter (brush hog) would be best for mowing the bullrushes and tules IMHO, and would also mow the vegetation along the roads -- cost $500 to $1200 for a new unit, depending on size and manufacturer, but you may be able to find a good used one. HOWEVER, if you are really concerned about the vegetation choking out the ponds, mowing won't help. They will just come back thicker than before. Burning will have the same effect.
I am aware of two methods for reducing the bullrushes and cattails: (1) rent a mini-excavator, so you can reach out and take out enough material to get most of the roots -- you might have the problem then, of what to do with the material you remove, unless you just pile/spread it on the banks and let nature take it's course; or (2) get someone who really knows what they are doing to deepen and reopen the ponds by blasting -- Wildlife refuges use this method a lot, but it requires someone trained and experienced in the use of explosives to ensure the desired result. It is not recommended if you have buildings with windows or neighbors close who would object /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif -- the "waste" material gets spread by the explosive in this case /forums/images/graemlins/wink.gif. Your local Fish and Game Department may have someone or be able to recommend a qualified blaster.
With the mini-excavator method - depending on the size of your ponds - you may be able to pile the waste material and create nesting/resting islands in the ponds. Also, since mini-excavators have tracks, rather than tires, they may be able to get around on soft material easier without geting stuck. The specs I have seen often show only 4-6 lbs/sq. in. track pressure. Around here (Central VA), I can rent a mini-excavator for $500-$700 per week.
Good luck.
   / What cutter to use on Bullrush/Tules? #3
</font><font color="blue" class="small">( Around here (Central VA), I can rent a mini-excavator for $500-$700 per week.
)</font>
Around here a lot of the rental yards have a weekend deal. Pickit up friday afternoon and have it back monday by 8 am, and its a one day charge. If the machine has less than 8 hrs on the clock.
But in my experince you can use a machine for a whole weekend and stay under the 8hrs if you shut it down when not in use.
Last time I rented a miniexcavator I think it was ~$150 for the weekend.
Of course it takes quite a truck to pull one. So you may have to pay for delivery.
I agree that this would be a good way to cleanup the pond.
Fred
   / What cutter to use on Bullrush/Tules? #5
Have you considered using an aquatic version of glyphosate (Roundup). They are marketed under various names but the one I use is Aquaneat. It works great on cattails. Mowing is just a temporary solution.
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2025 JMR 44in Bucket Skid Steer Attachment (A51691)
2025 JMR 44in...
2001 XL SPECIALIZED XL 80 MDE DOUBLE DECK TRAILER (A53426)
2001 XL...
