What compares to a JD 3520 with a 300CX
   / What compares to a JD 3520 with a 300CX #1
Doug_Norman
Bronze Member
Liberty Hill, Texas
Kubota L3130 HST
I've been looking at the John Deere 3520 with a 300CX loader. The trouble is the loader can't do some boom/bucket operations simultaneously (see JD thread). I've contacted JD, but so far they haven't answered me - kinda felt like they wish I'd go away so they didn't have to admit the problem. So now I'm shopping around, but I don't know about NH tractors. Can someone tell me what NH setup might compare? Also, maybe explain differences and pros and cons.
Thanks,
Doug
   / What compares to a JD 3520 with a 300CX #2
A 3520 equivalent would be the NH TC35DA. Actually the 3520 has more engine horsepower (37 vs 35) but the same PTO horsepower (30 vs 29.6). In most locations you could step up to a TC40DA for about the same price as a 3520. This is very region specific, but in general this should hold true. The TC35DA and TC40DA are the same size tractor, but with the TC40DA you would step up to a 4-cylinder engine, 20 more cubic inches displacement, more 3-PT lift (about 300 lbs) and of course more HP over the TC35DA.
The NH TC40DA (or TC45DA) is one of my favorites of all the CUTs out there. My next tractor (hopefully) will be this one. If there was ever a clear cut winner between two tractors, this is it:
NH advantages:
4cyl vs 3cyl
2.0L vs 1.5L (121.7 cu in vs 91.3 cu in)
Two range hydro with dual speed function within each range
14.9gpm hyd flow vs 13.9gpm
130 lbs higher 3-pt lift capacity
400 lbs higher FEL lift capacity (2000 vs 1598)... Plus as you mentioned the 300X/CX cannot raise and curl simultaneously. All NH loaders have that dual function.
Standard flex link ends & crank style leveling device
Swivel seat, telescoping steering
Flow thru radiator
Check out the hood on the 3520, it flexes quite a bit. The NH has dual gas assist struts that raise the hood.
NH touts superior visibility and serviceability
Four headlights vs two
Std tires are quite a bit larger
Supersteer may be of interest to you (approx $1500)
As for Deere advantages, they have eHydro but I don't know how much value that brings to the equation. The only thing that the standard eHydro has that NH doesn't have is Load Match, which is essentially the same thing as the dual speed function on the NH, except it is automatic instead of manual. Also the Deere engine is turbocharged vs naturally aspirated. Make sure you start up the 3520 and see it in action before you buy it. It may be just the one 3520 that I saw, but darn it smoked and banged. I personally liked the 4010 series better than the 3020 series.
   / What compares to a JD 3520 with a 300CX #3
</font><font color="blue" class="small">( I personally liked the 4010 series better than the 3020 series.
)</font>
I ran both, the 4000's smoke even more. Even when warm.
   / What compares to a JD 3520 with a 300CX #4
Pdub, for someone who doesn't own a TC40DA, you did a darn nice job of describing it's features. If you ever get one, I think you'll love it. /forums/images/graemlins/cool.gif
UNUSED AGT ATK-B1000 2 POST HYD CAR LIFT (A51244)
UNUSED AGT...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2021 JOHN DEERE 524L LOADER (A51242)
2021 JOHN DEERE...
2015 Chrysler Town & County Van (A50324)
2015 Chrysler Town...
