what causes the 30amp fuseable link to blow in a lk 3054 kioti
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #1
ronHD
kioti LK3054
what causes the 30amp fuseable link to blow on lk3054 koiti
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #2
There is a short somewhere. Does it blow right away or only when starting or using the glow plugs?
thanks for the input.....it will run just fine then you notice that the tractors temp gauge and no instrument lights are working.after shutting the tractor off ,it will not crank untill the 30 amp fuse is replaced again!!
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #4
Usually a short or an overload.
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #5
Sounds like an exposed wire making its way to ground. When it blows the fuse use a test light to make the connection across the fuse. If there is a short the light will be on. Wiggle wires until the light goes off or if the light is off wiggle wires till it comes on. Normally that will lead you to the problem.
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #6
40A
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #7
So he can burn up the tractor…? Post #5 is a good place to start.
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #8
10 amp increase won't roast the tractor but the issue is a dead short somewhere. Use a voltmeter or continuity tester to find it.
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #9
Replace the fuse, start it, but don't move or operate anything. Then shut it down immediately and see if it restarts or blows the fuse again. Since it's probably a short, just use a 10 or 20 amp fuse until you find out what system is involved: seat, starter, lights, instruments, etc. Could be a mouse or chipmunk chew, or a lever rubbing against a wire that has lost it's insulation. Since it runs with the fuse out, there's a hint as to the root cause.
   / what causes the 30amp fuseable link to blow in a lk 3054 kioti #10
Not really, nothing electrical needed to keep it running, all mechanical. Electrical system only powers starter, gauges & lights.
Agree there's probably a chafed wire somewhere.
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
John Deere 922 Platform (A50514)
John Deere 922...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
UNUSED FUTURE MINI EXCAVATOR HYD HEDGE TRIMMER (A51244)
UNUSED FUTURE MINI...
UNUSED FUTURE EQUIPMENT SEAT (A51244)
UNUSED FUTURE...
