What belly mowers fit a TC45
   / What belly mowers fit a TC45 #1
Flatheadyoungin
Veteran Member
Southern, OH
New Holland TC45 Shuttle
I'd like to keep an eye on the used market and I'm not sure what to look for.
It can be any brand, as long as it fit a NH.
   / What belly mowers fit a TC45 #2
Jeff, are you sure you have a mid-PTO on your TC45A? That is an option even on TC45DA models. If you don't have it, it would be quite expensive to add. You would be much better off using a rear finish mower (RFM). I don't know of any MFMs that use the rear PTO. All the NH ones use the mid-PTO which operates at 2000 rpm.
Good point, I doubt mine does....
gonna head back out and work on an old bush hog that one of my buddies tore up......grade 5 bolts for the sheer key and stumps don't like each other.....
i'll post an update on here later tonight...
thanks for your help
   / What belly mowers fit a TC45 #4
Jeff, I have a similar setup as yours (only a TC40D) and was told by NH that a MMM was not compatible with a backhoe due to the front mounts using the same mounting location on the tractor. I have been using a Woods 84 RFM for the past 6 years and have not hand any issues.
another valid point...
well, that's terrible.......i guess i'll just have to tell the wife a MMM won't fit and i need a zero turn!:rolleyes: :D
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
RCcar RC-G2.0 Electric Golf Cart, New! (A52384)
RCcar RC-G2.0...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53472)
2020 Massey...
VULCAN STAINLESS STEEL STEAMER (A51248)
VULCAN STAINLESS...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
Pull-Behind Rotary Brush Cutter PTO Attachment (A51691)
Pull-Behind Rotary...
