What are the mechanics of a check/ bypass valve?
   / What are the mechanics of a check/ bypass valve? #1
Hersheyfarm
Veteran Member
NE ky
Are they able to be cleaned or just replaced. My m59 lost both pumps and still has issues but has good pressure. I have issues with specific circuits and I'm going to take out the check valve and look at it. Any advice?
   / What are the mechanics of a check/ bypass valve? #2
Yes, you can remove, clean, and replace parts on some check valves.
Check for debris, holding the valve open.
Check for broken spring.
Did adjusting screw come loose?
Watch out for parts springing out. You could lose a ball or spring.
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
BRAKE PADS (A53843)
BRAKE PADS (A53843)
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
