What Are My Compact/SUB-Compact Cab Options, with Kubota--WITH Heat & A/C?
   / What Are My Compact/SUB-Compact Cab Options, with Kubota--WITH Heat & A/C? #1
My Hoe
Platinum Member
NYS--Various Parts
Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
Hi all,
I've been away for a few years. After being my wife's Primary Care Giver as she survived stroke, then breast cancer (though there's a second, not so scary surgery we've been putting off, re: that) as I say, I've been away from all things Kubota (except I've kept up with my KTAC policy payments). So, no time for tractoring.
So...we're (finally) beginning to see ourselves getting closer to moving to the place we bought, years ago, with the barn and garage. The Kubota is not here yet, but will be making the trip this summer. Unfortunately, the garage doors are only 6' 11 and 3/16" tall. IIRC, my fatory-cabbed, 2012 B3000, with or without the 7.7' BH, is 7' tall--does that sound right? (I'm not co-located with the Kubota right now.)
My neighbor (a future Kubota owner, I'm sure) is convinced there is a FACTORY-cabbed version of the BX--I was skeptical and finally went on the Kubota site, just now, and I can't find one--did I miss it?
EDIT: I got (slightly) smarter and "built" a BX2680, and I see now that a HEATED, but not Air-conditioned, DEALER-installed (factory-accessory) cab IS available: "1 DELUXE CAB (DEALER INSTALLED) $4,679.00 (BX4070)"
So...is there any way to get a BX's cab AIR-CONDITIONED?
If the only option for an Air-conditioned cab is a B-series, what is the shortest, FACTORY-cabbed B-model, with heat and A/C?
I also saw some smallish-looking, new B-model Kubotas, outside the local dealer, with cabs, and they looked surprisingly lower than my B3000. But admittedly, I don't see my B3000 much, and it looks enormous inside it's 20', 9.5' tall, shipping container, which it comes **** close to filling, lengthwise, what with the FEL and hoe attached.
Thank you all, and it's good to be back, even briefly.
My Hoe
   / What Are My Compact/SUB-Compact Cab Options, with Kubota--WITH Heat & A/C? #2
Kubota does not offer a cab for the BX series. The smallest Kubota tractor with an available factory cab is the B series. Note the B2650 and B3350 are soon to be replaced with the forthcoming and similar LX series.
Edited the LX typo.
SDT
   / What Are My Compact/SUB-Compact Cab Options, with Kubota--WITH Heat & A/C? #3
Kubota does not offer a cab for the BX series. The smallest Kubota tractor with an available factory cab is the B series. Note the B2650 and B3350 are soon to be replaced with the forthcoming and similar BX series.
SDT
Two corrections are needed.
1. The BX2680 can be configured with a factory cab (Bx4079) for $4,679 it has heat but not AC.
https://apps.kubotausa.com/configurator/BuildMyKubota.aspx?pgId=1&bmId=1130&sId=122 On the Step 2 Options,CAB Enclosure
2. The B2650/B3350 will become the LX series.
Added in Edit:
Perhaps this will be useful:
Kubota BX4:p Cab For the BX8-Series Tractors
   / What Are My Compact/SUB-Compact Cab Options, with Kubota--WITH Heat & A/C? #4
Added in Edit:
Kubota BX47 Cab For the BX8-Series Tractors
The non air conditioned cab available on the BX2680 is a dealer installed Curtis cab not made by Kubota. That said, it is "offered" by Kubota, so fair enough.
Corrected the BX/LX typo.
SDT
   / What Are My Compact/SUB-Compact Cab Options, with Kubota--WITH Heat & A/C? #5
Although pricey,Laurin in Canada probably makes a BX cab that could be air conditioned.
Best Wishes!
   / What Are My Compact/SUB-Compact Cab Options, with Kubota--WITH Heat & A/C? #6
Welcome back. I built a nice heated cab about 7 years ago to fit into our shed. We bought a slightly larger tractor w/ factory A/C and I built a shed with a door big enough for the tractor. I toyed with the idea of a larger door in the old shed but the shed itself was already cramped with the L3200 and other stuff.
   / What Are My Compact/SUB-Compact Cab Options, with Kubota--WITH Heat & A/C? #7
it may be cheaper to change the door height. especially if the tractor is already paid for
I just had it done for my garage went from a 7 foot door to an 8 foot door for the L4740
10 YARD ROLL OFF CONTAINER (A45046)
10 YARD ROLL OFF...
2016 UTILITY VS2RA 53FT REEFER TRAILER (A43003)
2016 UTILITY VS2RA...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A44391)
2013 International...
New/Unused 2025 KRW232 Skid Steer (A44391)
New/Unused 2025...
1987 Custom Aluminum Tanker (A39160)
1987 Custom...
2018 FREIGHTLINER CASCADIA (A45046)
2018 FREIGHTLINER...
