Mowing What about mower deck types?
   / What about mower deck types? #1
smallfarmer
Bronze Member
Kubot BX2350
Am getting a BX2350 with loader and I'm wondering if a Rear mounted finishing mower might be better than the standard mid mount 60 inch. I like the idea of rear discharge on the rear mount but I don't know about the durability of an aftermarket as compared to the Kubota MMM. What are the pros and cons?
   / What about mower deck types? #2
Better? Depends on what you are going to do. I have the 54" mid mount and one of the things I liked was I could have the loader on with the mower and the landscape rake all at once and trailer it to the next town to do more than one project at a time!;)
   / What about mower deck types? #3
That is a good question, especially on a tractor the size of the BX. One guy I know uses a RFM on his BX for mowing around his Christmas trees. Grass clippings, blown on the lower branches will kill them, so the rear discharge is a huge advantage for him.
If you have a lot of small rocks, trees, etc., to mow around perhaps the MMM is better. However, if you have lots of bushes, shrubs, or trees with low branches, it is much easier to sneak a RFM under there.
Another consideration not often talked about is traction, and stability. RFM's ride on the ground, so you are pulling that weight, and on side hills, that weight is free to swing down hill. I would think that front weights would be a good idea since RFM's tend to be heavier than MMM's, and surprisingly, sometimes more expensive. The MMM on that tractor is a suspended deck, so the weight of the mower is added to the weight of the tractor for stability, and traction. That weight is also below the axles so it lowers the center of gravity.
MMM's are specific to the model tractor you have, and can't even be interchanged between the early BX models (BX2200, etc) and the current 50 series tractors, nor between the BX1850, and the BX2350. A RFM can be used on all tractors that share the hitch size it was designed for.
Woods, and Landpride have very nice RFM's designed for your tractor, and they should last every bit as long as a MMM would. The only one I've seen on a BX is the Woods rear discharge unit that the Christmas tree guy has, and he has been very happy with it.
Good luck with your choices!
Thanks for the advice, I still got some thinkin' to do but will probably go with the MMM
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
2010 DODGE RAM 2500 FLATBED TRUCK (A51243)
2010 DODGE RAM...
2014 Peterbilt 337 Forestry Grapple Truck (A50323)
2014 Peterbilt 337...
FORD 2810 TRACTOR (A51243)
FORD 2810 TRACTOR...
2014 Mack CXU613 Semi (A50514)
2014 Mack CXU613...
