what a pita
   / what a pita #1
bluewatermassey
Elmwood Ontario Canada
Massey Ferguson 1973 MF 20 ind 1968 MF135 1969 Cockshutt 1450, Alis chalmers 1950 wd & 1957 wd45, 2009 Montana u4384c LS built (u5020c)
Just did a oil change on my 2009 Montana u4384c.
It's the same tractor as the LS u5020c.
Would love to find the moron that designed this setup.
Qil plugs (there are two of them as the front drive shaft goes through the middle of the oil pan) are directly above a cross member for the loader and you can't get a drip pan in there between them so oil splashes all over the place.
The oil filter is located on the right side of the motor dead centre\right behind the loader frame main support
directly above the tractor frame and right below heater hoses and hyd lines and just behind the hyd pump.
Can't get any kind of a filter wrench in there and i own lots of different types from metal strap fabric strap one one that fits on the top of the filter looks like a big socket.
Can't even drive a screw driver through it an twist it off as there no room to turn it. (red neck style)
Finally got my arm twisted around a lot and using a rag managed to turn it enough to loosen off the filter.
Now that I got it off of the threads and oil splashed all down the side of the block how do you get it out of there.
Won't drop st8 down frame in the way.
Towards the front there is a hyd pump is right there.
Up has hyd lines in the way and the exhaust manifold.
Back the loader frame and cab spacing is to narrow.
Finally managed to wiggle it around the hoses and electical wiring up n back then up n over then up past the exhaust n muffler and the out past the top of the motor.
Took about another 1/2 hr to figure this route out of there.
Replacement filter went back in about the same way.
Then had to tighten oil filter back on.
As it didn't leak I must of got it tight enough but its hard to get torque on it with your arms twisted in unnatural ways
Whole oil change and grease job took me 3 hrs and lots of cuss words.
Did my massey 20 and cockshutt 1450 afterwards and they both only took me 45 min and the massey is a back hoe loader with about 400 grease fittings.
You would think in today's world they could have done a better job in planning the layout.
Yes I know its a Mitsubishi motor they out sourced but they could have relocated the
two oil plugs.
They could have been moved 2 inches forward and there's still another 6 in of oil pan there to place them would give a clear shot to the drain pan.
And the left side of the motor has a least 2 sq ft of open space to place the oil filter or they could have installed a remote oil filter setup.
I'll be looking into installing one of these in the future as I've used them before on a few hot rods.
It's no wonder the dealer charges so much to do this regular maintance job.
Don't get me wrong I love my Montana tractor its the nicest one I've ever driven and I've driven and worked a lot of them.
Test drove even more.
But now that it's out of warranty I'll be doing my own repairs and maintance work. :mad:
Also posted in the montana forum
Will be doing the hyd filter n fluid change then the fuel filter next week .
Heard fuel filter is a pita as well but at least it and the hyd filters are easy to get at.
   / what a pita #2
I love my Montana as well but I didn't have any of that trouble with mine. Mine is the equivalent of an LS R4020 (new R4047) and everything is real easy to reach and change for the referenced work although the dip stick is a little hard to get at. I guess since you are lucky enough to have a cab you have to have a hard time doing maintenance!
   / what a pita
Actually every thing else I've had to service has been a breeze, easy to locate and easy to replace
You should try locating the dip stick inside a dark tractor shed with out a flash light minesright behind the loader frame behind all of the hosing and wiring harness
But with a cab I can hardly wait to change the clutch n pressure plate hopefully that won't need to be done for a long time.
i have 3 other tractors and operate 2 others for local farmers all of which have no cab
but for all my winter work i wasn't going to do it any more with out the cab and seeing as where i live we went 47 days below zero and i need it almost daily you get the picture.
15KW Kohler Trailer-Mounted Generator (A52128)
15KW Kohler...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A52128)
2018 Dodge Ram...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
