What a difference a large tractor makes!
   / What a difference a large tractor makes! #1
defranks
Crab Orchard, TN
Branson 4220
Last Wednesday I made a lumber run and loaded up my 24' box truck with T&G paneling for the interior of the house I'm building. I decided to just leave the lumber in the back of the truck, out of the weather, then to back the truck up to the porch and pull lumber as I need it. In the meantime I parked the truck over in a corner where I always leave it.
About one this afternoon I decided to move the truck over to the house to have it ready to go tomorrow. But sonofagun, the right rear dual tires were sunk down into the mud after a couple of really hard rains, and the old girl wasn't going to pull herself out. I hooked up my Branson 4220, put my wife in the truck, and tried to pull it out.... no soap. It just happened that a neighbor dropped by, and he went home and got his Kubota tractor, about the same size as mine. He pulled, I pushed, and my wife ran the truck and it went.... nowhere.
I have another neighbor with an old International agricultural tractor, sorry I don't know the model but it's about twice the physical size of my tractor. I called him up, he brought his two-wheel drive tractor over, hooked up a long chain and putt-putt-putt, my truck came out of the hole. Now I'm wanting a big tractor, darn it! There's one sitting in a barn up the road that hasn't moved in years. I wonder if the owner will let it go cheap.....
   / What a difference a large tractor makes! #2
Size has almost nothing to do with it. The difference is TRACTOR WEIGHT.
   / What a difference a large tractor makes! #5
NOT completely true, tire size and balance has a lot to do with it too!
From everything I read, Harry Ferguson, the inventor of the Three Point Hitch, figured the optimum balance for a 2-WD tractor is 40% front, 60% rear. Like the Three Point Hitch, 40/60 weight distribution varies only a smidgeon between Three Point Hitch equipped tractors.
Not quite sure if that is exactly the same with 4-WD, which became practical after Ferguson's death, but since the Three Point Hitch virtual hitch point is in front of the tractor, 4-WD may be an irrelevant factor relative to optimum weight distribution for traction.
The new factor is the almost ubiquitous fitting of Loaders on compact tractors. The position of the lowest pivot on Loaders varies. The weight of Loaders varies.
HEARVIER TRACTORS are equipped with larger wheels and tires.
   / What a difference a large tractor makes! #6
When you need it; you need it, but it doesn't make sense to buy a big mother of a tractor for the rare, probably <5% of the times you need something like that. You buy what you need for the 95% and hire or borrow for the 5%. Same for tractors, cars, trucks, chain saws.
I ran into this situation of how much difference something bigger makes when it came to drilling the concrete holes for our safety cover for the pool many years back. Tried with my own impact drill and concrete bit. Took forever to do one or two holes. So, I went to the rental place and rented one of those big drills. Ziiiipppp. Hole done. Ziiiiipp. Next one. Buy a big drill and keep it sitting around? No.
Ralph
   / What a difference a large tractor makes! #7
Larger wheels/tires yes, but NOT larger to farm tractor standards, and the OP said a farm tractor was used.
Not to mention, I can add lots of weight to one of my tinker toy tractors, get it just as heavy as a farm tractor. Do you REALLY think my weighted tinker toy tractor will pull as much as my farm tractor???
SR
   / What a difference a large tractor makes! #8
.............Tried with my own impact drill and concrete bit. Took forever to do one or two holes. So, I went to the rental place and rented one of those big drills. Ziiiipppp. Hole done. Ziiiiipp. Next one.............................................
There's a big difference between a rotary hammer and a hammer drill (maybe what you call an impact drill). I have corded and cordless SDS drills that will do up to around 1" holes in concrete lickety split with one hand and minimal pressure. I have a cordless hammer drill that is a decent drill for wood and steel, but is worthless on any masonry except maybe 1/4" holes for plastic anchors in cinder blocks. With a hammer drill you can hear the bit being impacted and it sounds more like a machine gun. The hammer drill sounds higher-pitched and more like an angry bee. It uses standard masonry bits.
Most of my drilling needs are handled with a 1/4" DeWalt 20V impact driver and a keyless impact-ready chuck. For heavier duty drilling I do go with the hammerdrill (on "drill") or a corded drill.
   / What a difference a large tractor makes! #9
I have a cordless SDS drill, a corded SDS max and a few of the hammer drills with a chuck. ( not impact drivers ). The hammer drills with a chuck are almost useless. They hardly hammer and won’t hold a bit very long. I haven’t tried any big holes with the SDS but it does a great job for little holes for concrete anchors. It’s also great with a chisel for tile removal. The SDS max is the only way for big holes.
Ralph
You're right about this, of course. I'm not really looking to buy another tractor, as my Branson is just about the perfect size for what I need. It's small enough to fit in some tight places, but large enough to do almost everything I need. But it sure wasn't budging that truck.
I'm very fortunate to live in an area where neighbors help one another. I just moved here a year ago, and while I might need to grow my beard a yard or so longer to really fit in with the hillbillies here, everyone has been friendly and helpful and welcoming. It feels pretty great to know that folks help one another around here, which wasn't quite the case where I moved from.
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52748)
John Deere 1110...
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
