whodat90
When I first moved to my new place (6 acres) I picked up a B7200D with a 5' RFM for mowing duties. 1000 hours, and never a problem other than a dirty fuel tank (how quickly I forget; also had to split the tractor to replace the transmission shaft pilot bushing and replaced the clutch while I was in there). After two years of that I realized that was madness, sold the RFM and picked up a Grasshopper 721 frontmount. Much better. This, however, left me with a turf-tired tractor with no loader; not exactly useless, but certainly not often used anymore. I wanted to replace it with a slightly larger tractor with ag tires and a loader. Looked for most of a year, then ran across a B8200D with a BF300A loader. Bought it, brought it home. Even came with a rather ragged 52" rear finish mower. So far, I have:
Changed the hytrans fluid once and cleaned the strainer. Fluid was seriously waterlogged, and the hydraulics were nearly unusable. Draining and cleaning again this weekend to get the last of the old stuff out.
Changed the engine oil and filter.
Ordered two new front tires; the ones on it were 2-ply, and the manual I got off ebay specified 4-ply due to the loader.
Bought an operator's manual off ebay.
Bought a new battery; old one was junk. Still have to weld up a new battery tray as the old one was corroded away.
Bought and installed a new rectifier/regulator, as the old one failed.
Cleaned and lubricated everything, including drilling and tapping for new grease fittings on the loader bucket pins as they had broken off.
Adjusted the brakes.
Tach didn't work, hours were at 247. Ordered and installed a new tach cable. Tach still didn't work. Looks like the cable rusted and broke, and when it continued to not turn it chewed up the gears in the tach drive gearbox. Going to order that later today.
Replaced rear lights with tractor supply models; originals were broken.
Ordered fog lights to mount on rops to replace broken headlights.
Ordered new loader stand arm, one was missing.
Replaced various and sundry clips, pins, etc.
Here's the fun bit; after a day or so of operating it started to make a wierd popping through the intake. I figured sticky lifters, and made plans to run some motor flush through the engine. Before I did, I decided to pull off the valve cover to see which one was sticking. Turned out that the end of the decompressor rod (~1/2"d steel rod that roatates to hold the exhaust valves slightly open to assist in cold weather starts) had broken off and rattled around till it laid on top of two intake valves, bending the lifter rods. Ordered two new ones (less than $5 each!) and beat the old ones flat with a hammer and reinstalled to use till the new ones arrived. Ya gotta like that kind of serviceability.
So now I have to sell the 7200, but when all is said and done I'm still happy with the 8200. It needs a bit of love but what doesn't?
Does anyone know of any gotchas on the 8200, or happen to know the lift specs on the BF300?
whodat
whodat
