Rotary Cutter What 6-ft Rotary Cutter?
   / What 6-ft Rotary Cutter? #1
SEEDSNTREES
What is everyone using for a 6-ft Rotary Cutter?
TT60A New Holland tractor, corn stalks, general field / trail mowing.
RHINO, LANDPRIDE, WOODS OR BUSH HOG?????
Thanks,
   / What 6-ft Rotary Cutter? #2
You wont go wrong with any of the ones you listed.. A lot of ppl own the 2nd tier brands and have gotten good service out of them for a lot less money.
Brian
   / What 6-ft Rotary Cutter? #3
Get the Bushhog, don't fool around.
jeez, a 60hp you should be able to run a lot bigger than 6'.
   / What 6-ft Rotary Cutter? #4
I also say Bushhog. The others are good also, but for my money it'd have to be Bushhog.
   / What 6-ft Rotary Cutter? #5
I've been using a 6' Bush Hog SQ172 for the past year and I love it, no problems here. I'm also in the market for a TT60A like you have, mind telling what kind of deal you got on that tractor?
   / What 6-ft Rotary Cutter? #6
A few weeks ago I was in the market for a 5' rotary to replace my old, rusted out Mohawk. I just clip pastures and a few trails now, since all the heavy cutting has been done. My local Montana dealer found an "aged inventory", new 6' for about 1/2 price of a new Land Pride. This has a slip clutch and a 60HP gearbox, and works very well on both my tractors. There are some great deals out there if you take the time to look for them...Dan.
I ended up trading an IH 464 gas, but The starting price was $13,565 for the TT60A.
I gave $7,200 and my tractor. The IH was getting tired pretty fast and required an O.Haul.
I just love this machine. lots of power, very easy to operate and very, very easy on fuel. Everything is layed out with an easy reach. Just a plain easy to use tractor.
I love it!
Good Luck!
After further review, I don't care for the rear wheel framing compared to the Wood's design.
Guess I will go with the new Woods.
   / What 6-ft Rotary Cutter? #9
Owning a mowing business, I get to log more hours on some of my mowers in a single season than some people do in a lifetime. I WAS a Woods customer for a few years. Not any more. They just didn't perform up to my expectations. I had a couple medium duty and one heavy duty Woods. (MD172, BB840, BB8400)
I had some mechanical issues (the strut running from upper 3-point mast to the rear of mower kept bending when the "toggle" should have prevented that, and gearbox seal/gear failures on the MD172), a real issue with paint falling off in sheets (to bare metal) and Woods failing to recognize that as a legitimate warranty issue. Also, I was NEVER satisfied with the finish cut. They left too much grass/weeds uncut in tire tracks. Even with high lift blades, I wasn't pleased with the job they did.
The Woods mowers have been replaced with Bush Hog (286, 297, 406) MUCH better quality of cut, much better reliability of the mower(s). And, I've dealt with Bush Hog on a couple warranty issues (on one of my three 15' batwings) and will say they listen and they RESPOND.
My customers want 2 things. A good price and a nice looking finished job. Quality equipment that I can rely on helps hold down cost. That same quality equipment gives the good "finish". Nothing but Bush Hog mowers for me from now on.
I own several other Woods products. (RB84, HB84, HB72, Gill soil pulverizer) I'm please with them for the most part. The difference is, they don't see 500 to 1000 hours of use per season like the mowers do.
   / What 6-ft Rotary Cutter? #10
If I were you, from my research, I would go with Bush Hog 296!! Woo Hoo!!:D
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2020 GMC 2500 HD (A50120)
2020 GMC 2500 HD...
Agri Metal Tuff Vac 5000 (A50774)
Agri Metal Tuff...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
