Wet Tires
   / Wet Tires #1
crazyangel
Western New York
Kubota L5740-HST; Kubota RTV900
I had a brief moment of panic last night when I pulled my tractor out of the garage. I got out of the seat to adjust the box blade and noticed water running from the sidewall of my new rim guard filled tires. I had been clearing brush the previous day and thought I punctured the tire. After a moment of heart racing inspection I realized it was condensation. No puncture to be found. The garage was closed up all day and much cooler inside than out. So the fluid in the tires was cooler than the air. It was s humid day, and condensation formed as soon as the warm air hit the tires. Since this is my first go with filled tires it was a great learning moment!
   / Wet Tires #2
Yes, We all have those moments of Enlightenment. That is what makes life so interesting and interesting tractors too!
formerly Tioga Cty, NY.
Tom
   / Wet Tires #3
My rear tractor tires have been sweating the last two days too.
   / Wet Tires #4
I've had the same problem as my barn stays damp. I guess it takes a while for all that fluid to warm up. The only rust on my 261s is on the rims from condensation.
I need to dig out the stone floor put down a vapor barrier and then replace the stone.
Sounds like a good FEL job.
   / Wet Tires #5
Funny - I was in the garage last night and noticed that the fill level on my rear tires was clearly visible. 3/4 of the wheel was damp up to a distinct line beyond which the tire was decidedly dry.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2012 FREIGHTLINER CORONADO (INOPERABLE) (A53843)
2012 FREIGHTLINER...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2017 MACK CHU613 PINNACLE DAY CAB (A53843)
2017 MACK CHU613...
