wet brake fluid-Ym2620D-draining?
   / wet brake fluid-Ym2620D-draining? #1
Dick_Jermyn
Bronze Member
North Carolina/Union county/USA
Yanmar 2620D
I noticed that on the bottom of the wet brake housing there is a drain plug. When you drain your hydraulic fluid is the fluid pulled out of the wet brake case or do you have to drain each side seperatly?
Much thanks, Dick
   / wet brake fluid-Ym2620D-draining? #2
Probably drain each side.
   / wet brake fluid-Ym2620D-draining? #3
My FX28D takes the fluid from the transmission. There is a drain plug on each side of what I would call the master cylinder. I guess you drain it there. The manual I have for a 336 shows completely different set up--so it was no help. The japanese parts manual show my parts, but of course doesn't tell me what to do.
   / wet brake fluid-Ym2620D-draining? #4
It is a mechanically activated wet brake system. There is no brake fluid. If
it was hydraulically activated like a car it would use brake fluid. to
engage it. Cars use dry brakes . Most large tractors use a wet system with
multiple plates The fluid dissipates the heat better than air.
UNUSED FUTURE SKID STEER QUICK ATTACH MULCHER (A51244)
UNUSED FUTURE SKID...
John Deere 825I Gator (RUNS) (A50774)
John Deere 825I...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
Case 1825 Skidsteer (Non Running) (A50515)
Case 1825...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
