Well?
   / Well? #1
Darins
Stanwood Wa.
B7500
I have been having some problems with my well??? It is only 1 1/2 yrs old and we have great water 25+gpm. But lately I have no water presure. Before it would fill up my 80gl. presure tank in about 2 min. now it can't even keep up with it if we are running water. So I did a preasure check to see if I had a leak, But when it is full I can turn the pump off and it hold steady preaure all day. So not leaks. So I called the well guy and he said that I am only getting 110 to the pump? SO I check all connections and I have 240 at all readings. SO I think it is the pump in the well. But he said that the pump would not run at half presure. Could it be the brain box for the pump? Any help would be GREAT... Thanks Darin
   / Well? #2
I think it is the pump. What the well guy probably should have said is that the pump cannot run at half speed. Even at full speed, there may be sand in the pickup/impeller, or further up the line. One thing you can check (or your electrician can check) is the load on the line. If the pump is spinning freely with water, it will draw a certain amount of current. If the pump is clogged, but spinning slowly, it will draw more current than usual, and if there is cavitation, or low water in the well, it will draw less current than usual. Knowing which of these things is occurring will be helpful in figuring out what to do. I recommend getting the Franklin Electric Pumptec or Pumptec Plus (depending on what type of pump you have). <A target="_blank" HREF=http://www.franklin-electric.com/Prod_text/el_menu.htm>Pumptec page</A> It will diagnose the line draw for you, and is great protection for the pump. If you don't have to replace the pump, it is worthwhile insurance, andif you do, it will still protect the new pump. The basic model can be found for under $100.
   / Well? #3
Another possibility could be that you have a puncture, slice/rupture in the line going to the pump. Check if you have a check-valve at the pressure tank, on the line going to the pump. It should be brass, about 6 inches long and maybe 2 inches in diameter. If you do, then the tank would hold the pressure, but the line leaking would slow the fill time. And before anyone says that the check valve is at the pump, it is common practice to add another at the tank end of the line.
If you decide to pull the pump, there should be a shock arrester every 20 feet or so. These keep the pipe from rubbing on the well casing which is the major cause of pipe failure. These should either look like stars that fit on the pipe tightly with arms radiating out to grip the casing, or they will be a sleeve that clamps on the pipe and when you bring the ends together, it increases the diameter, again contacting the casing. If these are mising, then it sounds like the well guy tried to save himself a few bucks at your expense.
Another thing to check, is for a kink in the pipe. If it was kinked during installation, it creates a weak spot which has a good tendency to fail. Also, if there is a coupling in the line going down the well, it may have loosened up, allowing leakage. A coupler is always a no-no on the downward section. If there is one, and you don't want to change the line, make sure it is tight. Slightly heat the end of the pipe before you tighten the clamps.
Also, make sure you have a support rope or wire, and that the pump supports on this, and not the pipe. Stretching of the pipe is the 3rd leading cause of failure. This is all assuming that you are using poly pipe. If you have metal pipe, you might have leakage where the sections couple together.
Darn, I knew that being a plumber in a past life would pay off. The bill is in the mail. /w3tcompact/icons/laugh.gif
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2018 JLG 1644 4x4 15,000lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
DODGE PICKUP BUMPERS (3) (A50854)
DODGE PICKUP...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
2017 Bad Boy...
