The misses gave me shout today saying no water. She had been watering a lot this AM and pressure went away. Smart girl that she is, she hit the web and looked for things to check. In January I put on the Square D pressure switch new that had the arm on the side and the feature to shut the pump down in case of a water line break. She reset the arm and worked, then didn't. Built pressure to 56 instead of 60. My thought was that it wasn't compatible with her watering, so I put the old switch back on. I had the thought at the same time to check the pressure in the tank whilst it was empty, which was 31 PSI rather than 38 that I set it at in January. So my 9ish year old 85 gallon tank has a pressure leak. Is that enough to make that pressure switch all wiggy and shut down? Thoughts are appreciated gentlemen.
