Well Now I've done it
   / Well Now I've done it #1
wvrocks
Bronze Member
Tucker Co, WV
TC-33 DA
Well Now I\'ve done it
Went and ordered a new TC-33DA. 14LA loader with QA plate. 1 rear remote and grill guard. I also ordered a Bush Hog SQ600 rotary cutter with slip clutch, Bush Hog ATH7200 finish mower and a Bush Hog 35-07 rear blade. Delivered with filled R4's for $23000 + tax. I'll be sure to post some pictures once it arrives. Hopefully it will be delivered the week after Thanksgiving. Its going to be a long week.
So now that I've got the tractor on the way.... What's the best way to hook up some extra lighting on the rops?
   / Well Now I've done it #2
Re: Well Now I\'ve done it
</font><font color="blue" class="small">( Hopefully it will be delivered the week after Thanksgiving. Its going to be a long week.
)</font>
Looks like no sleep for you for a while. As far as lights, first thing you must do is read Henro's, I am goingn to drill my ROPS thread. I got some magnets from a supply house that I mounted a set of lights to. I hand the lights under the top bar so nothing can knock them off easily. I also then have the ability to point one backwards if I wish. You will find a connector on the right side of you ROPS for your electrical. That's standing from the back of the tractor. If I had my other puter I could post some pics of mine.
Good luck in your new rig.
murph
Thanks. I was thinking of using 3 lights under the ROPS, 2 forward and one rear. Probably use a homemade bar held on with u-bolts. Is the rear connector switched or always on? Anyone use relays or wire directly from the battery?
BROWN BDH-600 LOT IDENTIFIER 161 (A53084)
BROWN BDH-600 LOT...
2011 Liebherr L586 (A53472)
2011 Liebherr L586...
2016 Chrysler Town & Country (A51694)
2016 Chrysler Town...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
ECHO PE-225 GAS WEED EATER (A51248)
ECHO PE-225 GAS...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
