Well, I finally did it.
   / Well, I finally did it. #1
daTeacha
Veteran Member
Funk, Ohio
Made up my mind that is. I called the dealer this morning and talked with the brother of my salesman, who is out today. I told him to hang a sold sign on the Case DX-29 with 114 loader that I drove last weekend. They'll install a rear hydraulic valve and run plumbing to the loader hookup from there so I can put a grapple on it easily and get a plate to cover the opening left when they remove the mid-PTO so it doesn't get caught up on a log or something. It has R4 tires and yes, a hydro not gears. The thing is just way smoother to move very slowly than even my 'Bota in creeper gear. I just hope I picked the right size. With the ROPS folded, the hard points are 69" above the ground and 46" wide. I hung a 2x2 on the ROPS of the 'Bota and drove into and out of the woodshed without hitting the rafters, so I presume it will fit where I need to take it.
Whew, this has been a long process, but I appreciate all the give and take from you guys. I guess I'm now officially in the Red camp. /forums/images/graemlins/grin.gif
   / Well, I finally did it. #2
Congrats daTeacha, You must have an early rising dealer. I went through a long decision making process myself when I finally decided on a Kubota. As it turned out the dealer I went with was the best and the closest. He just happened to be in the rental business and also a dealer.
   / Well, I finally did it. #3
Congrats!
the Red Camp /forums/images/graemlins/grin.gif My PT is Red; also I have your machine's namesake [the original Farmall: they were a tough machine, though the "F" series carburation was much less fickle], but don't think either one applies here! /forums/images/graemlins/grin.gif
   / Well, I finally did it. #4
Congrats! I think you'll have enough tractor in that model. It's a nice tractor, enjoy.
John
   / Well, I finally did it. #5
Congrats and enjoy. Of course we all wish to see pictures!!!!!!!!!!!!! /forums/images/graemlins/smile.gif
   / Well, I finally did it. #6
You'll love it, one trip through the door with the ROPS up will clearance it for you. /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
I got over there today to talk with the guy I've been working with. I made some small changes. We looked at tire sizes. The Ags are 11.2 x 24 rear and 7 x 14 front. The R4s are 15 x 19.5 rear and 8.5 wide in the front. I went with the Ags and will be able to get into a 6 inch narrower place. The fronts are 6 ply with either style, and the rears are 4 ply with either style. I've never holed one of the Kubota ag tires, so I hope the same holds true for these.
I saved some bucks on the tires, which I put toward getting the Q.A. loader plate and matching bucket. The real farmer who makes up our hay is switching from the small rectangular bales to the large rectangular ones that will weigh 800 or 1000 lb each. With those bales to move around, I figured I might need a bale spear or something similar in the future. That move on his part is no small factor in deciding on the larger tractor, too.
Lastly, I'm going to have the hydraulic lines run up the loader arms and have another set of quick connects at the front where the Add-a-Grapple will connect. The dealer is going to get the Add-a-Grapple shipped to them so they can have it on the tractor and make up the lines right there. I figured that between the rollback and dump angles -- close to 80 degrees total movement, I think -- and the motion of the grapple up and down there would be a fair amount of movement to allow for. It'll just be a much neater and cleaner installation if the tractor, loader, and grapple is right there for them to fit it all together, with a lot less chance of hoses hanging all over the place.
Later, I hope to redo my 6' auction special home built rear blade to fit the Q.A. plates on the loader, add a cylinder to it, and have a hydraulic turn feature on the blade while the loader controls will allow me to lift and tilt it from the seat. It'll be like T'n'T on the front end, which should be about perfect for snow plowing. Of course, I might need to get another blade for the rear to drag snow away from the garage /forums/images/graemlins/laugh.gif, but that one will be nicer than the one I have now.
   / Well, I finally did it. #8
Super. Now we just need some pictures so we know you are not bull***** us (just kidding), but would like pictures none the less.
They're guessing about 2 weeks before the tires, valve, and QA plate and bucket arrive and are installed. They don't know yet about the grapple. It may come direct from Missouri (Precisionmfg.com) or it may have to come from another dealer in Ohio (Koenig Farm Equipment), depending on the marketing arrangements.
I'll be taking 75 high schoolers on a weekend long excursion that weekend, so I'm not sure exactly when it will be at my place. When it arrives, I'll get some pics posted for you guys. A size comparison between the DX29 and the B7100 should be interesting.
   / Well, I finally did it. #10
Sounds great! Those Case machines sure are Purdy! It'll be nice!
I would really like to see how the grapple is actuated. Will you use a third valve or diverter? Where is the control located? Of course, you will probably post pics of these things ( /forums/images/graemlins/wink.gif ) Thanks!
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
LEGEND  2615 (15) BAT WING (A52472)
LEGEND 2615 (15)...
378621 (A51573)
378621 (A51573)
2002 International 9200i Truck (A52748)
2002 International...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
