Well Filter
   / Well Filter #1
CharlieTn
Bronze Member
Cocke Cty Tn
Jinma 284
The well on my new property in NE Tn is 150ft deep and is full of particulate matter and iron. When the water is filtered through a cheesecloth and then a Britta filter it tastes great but when it does not run has a strong iron/sulpher odor.
Can anyone recommend a filtering strategy that works. We do a lot of wash and there are 5 people in the family. I imagine the home depot type filters would clog fairly quickly.
   / Well Filter #2
we have the same problem with our well: i installed a sand filter, i was lucky enough to pick up a used one, sold commercially, but prior to that, i had arkansas engineered one that worked just as well, but didn't look as good: the one i have now is about 2ft wide by 5ft long and 3.5 ft tall: its basically a fiberglass tank, with a divider in the middle: sand and gravel on one side, the water goes in on top of the sand, seeps down an into the other side: we have a pump on that side that pumps the water to the house: this aeriates the water to get the smell out and the sand removes the iron.works great.
heehaw
   / Well Filter
Thanks! Do you think a sand swimming pool filter would work?
Charlie
   / Well Filter #4
Greetings,
I have a similar situation with my well -- note my post earlier today on water treatment systems. We had just run the water for awhile on each visit and it would lighten up so we didn't think much about it. But then we had it tested and the news was not good -- the sulpur smell was from bacteria and they found lots of other bad stuff including ecoli.
So if you haven't had it tested, please do it soon. Culligan will do it for nothing as part of a sales call. And if they find something, a pool filter probably won't do the trick. Use the right tool for the job in this case.
Thanks,
Rod
   / Well Filter #5
I would use Granulated Activated CarbonRANULATED (GAC). It adsorbs organic contaminants, such as herbicides, pesticides, industrial chemicals, and trihalomethanes (THM's) and removes chlorine. Blows the heck out of the Britta. Coconut shell carbon is better but you could use GACto start. I would also use a Sediment Filter before GAC to.
   / Well Filter #6
You should have a Coliform bacteria test done. Regardless of the outcome you probably have IRB and SRB (iron and sulfate reducing bacteria). I suggest a special inline pellet chlorinator with a special mixing tank and then a backwashed Centaur carbon (turbidity) filter to clarify the water and remove the chlorine. The chlorine kills bacteria and oxidizes iron, manganese and H2S.
Otherwise you use ozone and a turbidity filter or hydrogen peroxide or liguid chlorine in a solution feeder with a properly sized retention tank.
Gary Slusser
   / Well Filter #7
lowes sells play sand, that they say has been sterilized(misspelled)..and its pretty cheap
heehaw
   / Well Filter #8
i've had my water tested, and don't have a bacteria problem, but i added an in line chlorinator, mainly because it helps with getting the iron out. i have helped people build a contraption to do this same thing, using an old bathtub and a plastic 50gal barrel: the tub gets the sand and gravel, and is mounted above the barrel, the water to the house is pumped out of the barrel: more barrels can be added, if more reserve is needed: it looks crude, but it worked.
heehaw
   / Well Filter
It tested OK. Actually is great when filtered. I figgered something upstream from the store bought filter system would save me time and money on filter changes. A call to Culligan is a great idea.
   / Well Filter
Thanks. Gettin pretty technical now. <G> Sooo much to learn. I thought rural=simple.
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
Kubota Salt-Spreader (A52384)
Kubota...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2005 Nissan Frontier 4x4 Pickup Truck, VIN # 1N6AD07W35C433334 (A51572)
2005 Nissan...
