Welding Tractor Forks.
   / Welding Tractor Forks. #1
gemini5362
Veteran Member
Ozark Mountains in Arkansas
Montana 4940C
I just bought a set of forks off of ebay. I thought I would write a bit about the fun I had making the Forks fit my tractor.
The forks did not have a quick attach so I am building one. The first thing I found out was that backing plate was narrower than the arms of my loader. I went to the local metal sales and they had a small piece of 1 inch that they sold me for ten bucks. The back plate on the forks is 3/4 thich by 12 inches tall. I cut the 1 inch piece to 12 inches tall and it was 7 inches wide. I had a friend at work help me and we machined the top and bottom of the 1 inch plate down to 3/4 of an inch at the top and bottom for an inch and a half on each so the forks would slide on it. I cut a 4 inch wide gap at the bottom to be able to get the forks out (the orignal backing plate had no way to take the forks off without taking the mounting bracket off and sliding them off the end) I then cut the backing plate in half and welded the machined 1 inch piece in the middle of the backing platte. I am very excited this is the first time that I have made welds that I am not ashamed to show my friends at work. Due to the thickness of the metals involved and the stress on the backplate I followed advice from some of the welding threads on here. I beveled all the edges of the metal I was welding then I made several passes grinding between passes to bring the weld up to the level of the surrounding metal. I have not finished making the rest of the mounting bracket but I have some 3 x 2 1/4 inch square tubing I am going to be making a bracket out of. I have 3 inch x 1/2 inch strap to make the top section of the quick attach out of and probably cut holes in another piece of the strap for the locking lever pins and then weld that to the bottom.
While I was at the metal sales shop on another date I saw a piece of 3/4 plate. I could have had them cut me a chunk of that 12 inches by 48 inches for 100.00 and used that for my back plate but I decided there would be no learning experience and not as much fun doing it that was as there was in cutting my original back plate and making it the right size. From what I am seeing if you can get forklift forks you should be able to make the rest of the assembly for 200.00 or less. I will write more about what I ran into making the mounting bracket and take some pictures when I am done
   / Welding Tractor Forks. #2
Pictures are priceless ....
   / Welding Tractor Forks. #4
Ditto on the pictures.
Those of us with Kubota scuts need to be mindful of the weight we are adding up front; our loader capacities are a bit wimpy (just my opinion-no flames needed). Your post mentions some heavy steel. I'm not familiar with the Montana models but be careful of infringing on your capacity if it is a light duty loader already.
   / Welding Tractor Forks. #5
exactly. i own a b6000. I am making forks for my 3 point hitch.
   / Welding Tractor Forks. #6
I found a great deal on some forks too!! Then after I had them here and started trying to figure out how to mount them, I realized that I could hook a chain around them and drag them behind my tractor to smooth out the ground really good. They are heavy enough to knock down the high spots and smooth everything out!!!! So far, I haven't had a real need for them as forklift forks, but sure have enjoyed using them to smooth out my dirt.
Eddie
Thank you for your concern. I have a 49 horse tractor and I believe the lifting capacity is around 2000 pounds. The forks are not going to be much heavier than the bucket they are taking the place of. Actually the bucket might be a bit heavier. I am not sure about the weight of the bucket but the forks are not all that heavy.
Eddie
I must admit that is not one of the things I thought about using them for but I will have to try that.
   / Welding Tractor Forks. #9
I got my bargain forks down at the local dump in the metal scrap pile.some old snow plow cuting edges. bolt them on the bucket and off i go to work. the bucket fatigued after 12 yrs. bucket cracked all apart. let it go for several months before geting out the welder. probably going to need some backing plate to prevent more fatigue. B.
Gas Powered Wood Splitter (A51573)
Gas Powered Wood...
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X8JD476306 (A51572)
2018 Peterbilt 389...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A53472)
New Lewis Brothers...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
Under Body Toolbox (A51573)
Under Body Toolbox...
2020 JOHN DEERE R4023 LOT NUMBER 94 (A53084)
2020 JOHN DEERE...
