Welding rates sky high? yes, no?
   / Welding rates sky high? yes, no? #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Got a phone call from a friend the other day asking if I could do a simple welding job for him. I knew that Gerald always used a local shop in the past and my curiosity got the better of me so I asked what was up?
Turns out that the local welding shop that has been in this area forever is now quoting 2 bucks a minute for services rendered. While the 2 bucks doesn't sound like much at first if you do the math that's $120.00 an hour to lay a bead! /forums/images/graemlins/blush.gif Guess I might understand that if they had to come to you with the extra expense of fuel and all but welding is a carry in issue for these folks, period.
Checked my watch and the job took me all of 25 minutes from setup to the finish for Gerald's item and as I handed him the part I winked and told him that the damages came to 50 bucks, but that I would settle for a cold beer (man I work cheap) /forums/images/graemlins/grin.gif
I'll put it to you, does $120. an hour seem steep to you guys? What's the going rate in your area for carry-in welding?
   / Welding rates sky high? yes, no? #3
Darn,
I'll have to print your post and hang it in the garage next time a buddy comes over for a weld!
It's a lot, but it doesn't surprise me. A pro shop has high expenses, and you can't get a pro welder for minimum wage............
And my welds are only guaranteed until they BREAK!
So does the clock stop while you down a cold one????????????/
ron
   / Welding rates sky high? yes, no? #4
Darn,
ron
   / Welding rates sky high? yes, no? #5
Mike,
$120 per hour for regular arc welding is extremely high IMO. If I was charged that much, I would go somewhere else or buy a larger welder.
   / Welding rates sky high? yes, no? #6
Mike,
   / Welding rates sky high? yes, no? #7
Maybe it's because I live in NE where everything is expensive, but I didn't even blink at $120 an hour. Of course the real estate, utilitiy etc, all equate to a higher overhead here even if they aren't paying the welder any more $$ (which they probably are).
   / Welding rates sky high? yes, no? #8
   / Welding rates sky high? yes, no? #9
Well, let's see. Here in NH the going rate for services rendered varies by trade. Here are some recent hourly rates I was quoted:
Carpenters $60-$70 /hr
Electricians $50-$60 /hr
Auto mechanics $65-$80 /hr
Roll back tow truck $85-$110 /hr (1 hr minimum)
I would guess that welders would be in the $60-$80 range depending on the type of welding being done. It seems obvious that the welding shop you mentioned is trying to discourage walk-ins. I'll bet they actually get their $120 /hr on contracted and bid jobs.
   / Welding rates sky high? yes, no? #10
1 pallet of Truck equipment (A53117)
1 pallet of Truck...
1840 (A51248)
1840 (A51248)
2021 John Deere 8R 250 (A50123)
2021 John Deere 8R...
2009 Wells Cargo 5th Wheel Office Trailer (A53117)
2009 Wells Cargo...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
