Welding on the FEL bucket
   / Welding on the FEL bucket #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
I've read several threads in this forum in which reinforcing plates are welded to the bucket to install toothbars on the FEL.
IIRC, it's recommended that the tractor's battery cables be disconnected before welding to prevent damage to the vehicle's electrical system.
I'm interested in whether people usually take this precaution or if it's not that important. Has anybody out there actually damaged his/her tractor's electrical system by neglecting to do this?
   / Welding on the FEL bucket #2
I did NOT disconnect and it did not adversely affect my Bota when I welded chain hooks and backing plates on. I hooked the ground clamp directly on the bucket to try to isolate the juice.
I do think it's a good idea to take them loose.
Ron
   / Welding on the FEL bucket #3
well im sure the best way is to disconnect the battery, thats what most truck and tractor manufactureres tell you to do, but i will say that i work as a mechanic for a garbage company with almost all newer computer controlled trucks, never have i or any one else disconnected the batterys before welding on them, we usualy weld on a truck atleast once a week, and have never had a problem, but we are carefull to keep the ground clamp near the area you are working also. recently we did install master disconnects in all the trucks, the insurance company wanted them, and now if i weld on a truck i do turn the switch off if i think of it, but like i said alot of welding was done on the trucks without ever disconnecting the batterys. your results may vary......
   / Welding on the FEL bucket #4
As others have already stated. Keep the ground clamp on item being welded. You should have no problems.
   / Welding on the FEL bucket #5
Another good reason to have QA bucket or just remove the FEL if able too and there will be no wondering if any harm will come to any electrical system.
   / Welding on the FEL bucket #6
Yeah - I just took the bucket OFF when we welded the plate on for my toothbar.
   / Welding on the FEL bucket #7
Taking the bucket off will allow you to position the bucket for flat welds which always look and perform better, easier too. At least my welds work this way. Those backing plates for toothbars act as big washers so really only need to be tacked.
The muffler shops never diconnect batteries.
Loflin 72in Quick Attach Skid Steer Grapple (A51573)
Loflin 72in Quick...
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53472)
2011 New Holland...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
