"Welding" Lexan or plexiglass?
   / "Welding" Lexan or plexiglass? #1
slydog
Southaven, Ms now, Greers Ferry Ark later
1955 Ford 640
\"Welding\" Lexan or plexiglass?
I need to make some permanent, waterproof bonds between sheets of Lexan or plexiglass. It seems I saw on one of these DIY shows someone making some chemical welds with a clear liquid that actually melts/bonds the joints together.
Does anyone know of this or any process for doing this? The boxes I need to make will be totally of Lexan or plexi, and will need to be totally clear so they will be transparent, and waterproof once they are embedded in some huge blocks of ice. (lol, I know I can come up with some crazy sheet, but I'll be happy to explain more later if I can come up with a practical solution to what I am trying to accomplish.) I know this doesn't have anything to do with tractors, but you guys know what your talking about and are full of answers.
Ken
   / "Welding" Lexan or plexiglass? #3
Re: \"Welding\" Lexan or plexiglass?
You may also want to consider that they use silicon RTV sealant to hold aquariums together some at over 100 gallons each. It is also very easy to apply with a standard caulking gun and available at stores like Home Depot or Lowe's.
   / "Welding" Lexan or plexiglass? #4
I use the Weld-On line of products from www.ipscorp.com on a regular basis at work. I use Weld On 16 mostly, since it's a clear gel that comes in a tube. I've also used Weld On numbers 3, 4 and 5, but 16 is really the easiest to use and most practical. You can see the products here:
http://www.ipscorp.com/ind_html/indprdcts.html
Lexan is the General Electric brand name for polycarbonate. I guess most "plexiglass" is also polycarbonate, but some people just use it as a generic term for clear plastic sheets, and many clear plastic sheets are acrylic rather than polycarbonate. I've found the above Weld On products that are designed for acrylic work great on polycarbonate, as well as ABS and PC/ABS blends. The specific polycarbonate epoxies are two parts from what I have seen, and it's easier to use the one part acrylic solvents, with not much reduction in performance.
   / "Welding" Lexan or plexiglass? #5
I made what amounted to an aquarium out of lexan. It is actually called a sump tank and water from my saltwater tank cycles through it. There is a product that looks like clear glue that fuses the pieces together and is very strong. It can be put on in enough "layers" to fill gaps and I believe this is what you are referring to. I don't remember what it is called, but I got it at the same place I bought the sheet of lexan from. Not H-D or Lowes, although they MIGHT have it, but a place that specializes in plastics I found in the yellow pages.
   / "Welding" Lexan or plexiglass? #6
I don't know all the technical jargon, but I thought there was a difference between lexan and plexiglass. I used to work in a sheet metal shop and glass companies would bring us lexan to put a break in and be used as sneeze guards. They said you couldn't break (bend) plexiglass and that it scratched easier.
It's true that many things pick up generic names that don't refer to that particular product.
I KNEW you guys would know where to look! My plans are to get the sheet goods at GE Polymer and Plastics, so I bet I can obtain what I need from them also. I didn't even think they might carry something for that purpose.
I am actually trying to come up with....an aquarium in reverse sort of. Tell me what you guys think.
This is for a huge party for a major movie premier here locally. They want a huge bar (as in alcohol type bar) made entirely of Ice. This ice sculpture company a friend works for will be providing the bar. Now where I possibly come in. They want to "imbed" or cut into each end of the front of the bar, and place a large flat screen plasma tv in each end. It has to appear if possible as if it is sitting actually in the ice. There would be a concern I'm thinking of the TV's melting the ice, or water running into/around the TV's.
My thoughts are, using thick, 1/2 to maybe 5/8, whatever looks best, Lexan, and building a box to place the TV's in. The front would be totally open. When I have the Lexan cut at GE, I can have them polish the edges, and it looks almost like clear ice then end on. I still don't know what kind of base all this ice and stuff will sit on, but my thinking is to come into the box from the bottom with all the wiring. Would anyone think I would maybe need some fans to pull the air out of the box to help cool the TV's ? Maybe two or three 3'' fans in the bottom of each box? Or with the front open, and surrounded by ice, would this even be necessary?
Do you think this kind of setup would keep the TV's dry? I'd hate to have a major short out in the middle of this production, IF I give a qoute and take this job on. I know lexan is expensive, but just to give yall an idea, I have been told there is an Ice Sculpture budget alone for this project of 40 to 45k !!!!! /forums/images/graemlins/shocked.gif Yes, some people have more money than brains! Whether I do it or not, I definitely want to see what it looks like when it's finished.
Ken
   / "Welding" Lexan or plexiglass? #8
</font><font color="blue" class="small">( I definitely want to see what it looks like when it's finished. )</font>
I don't think you are alone here /forums/images/graemlins/grin.gif
I'd like to throw a couple of things out to think about.
Does the lexan need to be that thick? I'm not sure how they will build the ice bar, but if they needed to build around the lexan boxes, you could put wood jigs in them so they retain their shape and take them out to insert the TVs.
I think how much room you allow around the TV (you can always go deeper without losing the desired effect and perhaps have a lip inward that meets the size of the TV screen around the face of the box, so the actual box is say, 50 x 30, but the TV is 40 x 20) plus the fact that they are surrounded by ice will keep the TVs at a good temp, BUT... I would be VERY concerned about condensation forming inside the box walls no matter hown much air flow around the TV you have. You will definitely need to build an insulated box (2" styrofoam would probably work well), but this will take away from the ice, or opaque look you are trying to keep. If you go with a lip around the face of the box it will help hide the insulation and maybe even make it impossible to see if you can recess it a ways.
IMO. Just a couple things to brainstorm. The vision I have in my mind of this project sure looks cool, though.
   / "Welding" Lexan or plexiglass? #9
How do they plan on keeping the ice bar cold so it doesn't melt? I imagine that the refrigration system they plan on using will keep the ice from melting even without the lexan sheets. The TV's will put out some heat, but the refrigration system to keep several thousand pounds of ice from melting over a period of 6-8 hours is going to be huge, so far as I can imagine.
The company I work for makes waterproof marine electronics. If you painted the outside edges of the TV's with clearcoat it would water proof the edges for enough time for the party to end. Another option is to just keep water from dirpping on the tops of the TVs. A splash shield of sorts above the TV would keep liquid water off the top of the TV, and gravity will keep water from dripping into the sides or bottom of the TV. Fogging may be a potential issue on the display. If the ice bar can drop the temp inside the TV below the dew point, the display is going to fog in the center. Using a five sided lexan box which allows the front of the TV to stay open to ambient may be your best choice. It would keep the temp around the TV up, and expose the TV to ambient humidity rather than an artifically increased humidity. I'm sure you can make this work.
   / "Welding" Lexan or plexiglass? #10
From reading your project description, I think you should consider augment the solvent/sealer with metal fasteners. Mortise or rabbet a channel for the corner joints, and sand a light chamfer on all outside corners to eliminate sharp corner interference in the matching groove corners. Drill and countersink an appropriate number of "through holes" for 1/4 or 5/16 bolts, and drill and tap into the edges of the sheet. Dry fit the assembly to ensure alignment squareness, and a good tight fit. Dis-assemble, apply the adhesive/solvent, then bolt securely and let cure per instructions. The bolts could be galvanized or stainless for a better appearance.
With or without bolts, a good accurate fit is a must. Any gaps that must be bridged with extra adhesive or sealer will fail first.
You may need to rent some de-humidifiers for the cubicles, because you're going to have SERIOUS condensation! /forums/images/graemlins/shocked.gif
Interesting project! Good luck!
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
Generac Generator (A51691)
Generac Generator...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
