Welding in the dirt
   / Welding in the dirt #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Because my last question was so successful for me I have yet another.
I have to keep the ideas on the cheap.....
I had a 8 x 14 pad of concrete under a wing of ny open wall carport pole barn that I welded on ( I have no welding table for the moment). It has allowed me to build a grapple with little issue. But I ran out of shop rom so I enclosed my pad. Today I realized as I started to plan building my land plane that I kinda screwed myself. All I have left is a gravel driveway. So how do you weld a large project that needs a level surface like a landplane without a level surface?
Carl
   / Welding in the dirt #3
woodlandfarms
I've used I beams and channels to set up a cribbing for bigger projects .I use tape measures& string to help establish squareness also. I've a few older tables and refrigerators that are flat too to weld on
ak9
   / Welding in the dirt #4
Other than suggesting prudent use of a level I can't help you but I thought I'd mention something I saw in a fabricating shop once. It was two I beams imbedded into the floor so that they had these two perfectly level beams to build off of. They could tack pieces to them or simply rest the pieces but everything was level and if following the edges square. The top side was flush with the cement floor. It was an idea that I would definitely incorporate myself someday.
   / Welding in the dirt #5
Go to your local auto wrecking yard and get 4 scissor jacks. Put a plywood or metal foot on each. Do whatever is needed to the top. Then you can level a project precisely without a wobbly stack of bricks, blocks, and wedges.
The old style vertical screw jacks work good, too. They are even more ridgid than a scissor jack.
Screw adjustable pier blocks will do it, too.
Bruce
   / Welding in the dirt #6
Looks like another successfully answered question. :)
The pier blocks are something I'll have to remember.
   / Welding in the dirt #7
Uhhh why not weld in the same area but maybe open the doors?
   / Welding in the dirt #8
Yup :thumbsup:
If you have to weld outside than as suggested use blocks , sawhorses etc to get everything leveled up.
You know this is a great excuse to finally build that welding table:D
   / Welding in the dirt #9
If you are exceptionally flush with money, just go to your local welding supply and buy some Sumner brand of adjustable jack stands. OR look them up on the internet and build some similar to them using bolt heads. The material isnt going to be cheap but you can use a pair with angle iron between them and make an easily levelled saw horse type of support. This is the brand we use on our construction sites due to their ruggedness and safety in designed of load rating.
Sumner Manufacturing Co., Inc. Sumner Manufacturing Company Inc. - Lifts, Jacks and Stands, Handi-Bench, Welding Tools, Material Carts and Pipe Supports
   / Welding in the dirt #10
I have to agree on its finally time to build that table!
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
377780 (A48837)
377780 (A48837)
STORAGE FEES (A51219)
2015 GMC Arcadia (A50324)
2015 GMC Arcadia...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
