Welding helmet help.
   / Welding helmet help. #1
Northstar9126
Bronze Member
I have a Hobart auto-darkening welding helmet that I bought several years ago that but have seldom used until recently (enrolled in a welding class at the local vo-tech). The helmet doesn't always darken to the same shade that it is set to. By this I mean that I can strike an arc one minute and the shade will be set properly then I can strike an arc a minute late and the shade will be too dark. The adjustment knob is not moved between arcs. The shade sometime changes to a darker shade as I am running a bead. I have noticed that if I turn my head to the side I am able to see the weld fine along the outer edge of the lens. Any suggestions on how I might address this problem would be appreciated.
   / Welding helmet help. #2
MABEY the battery is weak,is it cold where you store it? Try setting it in the sun for a while mabey
ALAN
   / Welding helmet help. #3
try posting on Hobartwelders.com with your question, they are very helpful
Electric Concrete Mixer (A51573)
Electric Concrete...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
