WELDING BLIND ?
   / WELDING BLIND ? #1
wildwillie
north Idaho
L3400,
Havent done any welding in a long time. Problem now is I can barely see what I am doing sometimes guessing witch way to go (not good) I bought an auto darkening hood that helped a little. Would moving up from a buzz box help?My eyes aren't what they used to be. Any advice would be appreciated.:confused:
   / WELDING BLIND ? #2
Dear Sir
I would guess that you are older than you use to be, try using a pair of drug store reading glasses 1.5 diopter or you can buy a 2x4 plastic lens to fit 1.5inside of a old style welding helmet, and set your lens to 10 I had to drop down from 11.
Craig Clayton
   / WELDING BLIND ? #4
Your welding supplier can help you out with a magnifier that goes inside of your welding helmet like Craig suggested. It's much cheaper than a new welder and will be more likely to be effective.
   / WELDING BLIND ? #5
Can't see because of lighting i.e. too dark? Or can't see due to focus/blurry view?
Too dark, get a lower shade number lens. For low amp work even #9 might not be light enough. Most of the auto dark helmets I've seen only go down to 9.
A helmet with a larger view port might help you get better view of the work area.
Also remove the lenses and clean them. I've found my helmets get very dusty sitting around the shop and the dust can block quite a bit of light.
As much as we hate to admit it, aging eyes may need some level of corrective lens. It might be as simple as a $10 pair of readers from the drug store.
   / WELDING BLIND ? #6
Is your eyes giving you problems when your not welding?
If they are then don't buy an 'auto darkening welding helmet' from Harbor Freight.- It will make your eyes get worse and possibly cause you to go blind.- I tried the HF helmet and it burned my eyes.- I have a Jackson welding helmet and haven't had any problems with my eyes, and all the welders at work use Jackson helmets.
Do a search on here for welding helmets.
   / WELDING BLIND ? #7
Dear Sir
Craig Clayton
These things are great - Clip on magnifiers
   / WELDING BLIND ? #9
You need to put some light on the subject, like a tripod halogen light. You would be supprised what adding an external light source to your welding area can do for seeing what your doing.
I know the arc from the weld adds light but try the extra light source and see if that helps, I know it helps me considerably.
   / WELDING BLIND ? #10
Try drawing a line where your weld will be with your soap-stone the white line makes a big differance. use a # 8 or #9 linse. I use a hand held face shield which helps me. Just my way of doing it.
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
**INOP** 2007 KOMATSU WA320-5L WHEEL LOADER (A51242)
**INOP** 2007...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2011 Ford F350 Service Body (A47384)
2011 Ford F350...
