welding a trailer frame
   / welding a trailer frame #1
Omar Torres
Dallas,Tx
cat
what type of welder is better to weld a trailer frame a wire or a stick welder
   / welding a trailer frame #2
If I had a powerful mig welder I'd pick it every time over stick. But, you'll need more power than a 120 volt wire feed unit unless you are just welding thin fender material.
If you already have an AC/DC buzz box you can do whatever you need. Even just an AC only one can do it if necessary, but some overhead stuff will be a bit harder. I usually turn the trailer over and do the underside welding and I use my AC welder more than anything else. I wish I had a nice mig machine, but I've done a lot of projects and a few trailers with stick.
   / welding a trailer frame #3
The amount of rust also has a little bearing on the choice of welders. A stick can run 6011 rods that will handle a little rust, but from what I hear, a mig doesn't like rust, so you have to prep the surface a lot better.(which you should do anyway)
David from jax
RING 2 STARTS HERE @ 9:30 AM (A51247)
RING 2 STARTS HERE...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2020 Kubota SVL75-2 (A50123)
2020 Kubota...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
UNUSED X-STAR 250 GALLON FUEL TANK (A51247)
UNUSED X-STAR 250...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51247)
UNUSED FUTURE BOX...
