Welder specs
   / Welder specs #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Just came back from my local welding store am
looking for a mig that will weld 3/8 in a single pass.Depending on which brand's flyer you read the amps needed for welding 3/8 plate varies.Millermatic 175 says up to 1/4.
Hobart Handler 180 says up to 5/16(which is Miller now) putting out 5 more amps.ThermalArc 190 brochure also says 5/16, 10 more amps ,guy at the store says 3/8 is no problem with the ThermalArc.Finally if I move up to the Millermatic 210 I get my 3/8 in a single pass......for a price.What do you guys use,I was under the impression that a 175 machine could do 3/8.
How are these machines rated,like horsepower net vs gross?
If I can get the 190 amp machine for $895.00 vs $1599.00 for the 210 amp and they will both weld 3/8 that would be a given.I think the key words here are "in a single pass".
   / Welder specs #2
I used a MM175 for all of my projects up until this spring when I upgraded to a MM251. The MM175 will do just fine on 3/8" although I used at least 2 passes for most joints. For the price, the MM175 is a very versitle welder. It did a fantastic job on 1/4" and sheet metal.
   / Welder specs #3
Another factor will be the duty cycle at that max rateing. Waiting for the welder to cool down can slow you down considerably if you have a project with a lot of welding. I have a smaller lincoln mig I use and it has a pretty good duty cycle up to 1/4". On my larget projects, I need to plan my assembly carefully so I can move to different processes(grinding, cutting, drilling) and give the welder a break without halting progress alltogether.
   / Welder specs #4
I run a MM 250 and just don't see doing 3/8" single pass welds satisfactorily.
Is that something you plan on doing regularly?
I would look at a 250 if it was me. Miller, Lincoln,,,, maybe ESAB or Panasonic. But probably Miller / Lincoln.
   / Welder specs #5
Here is what the guys at th nearest to me welding shop told me..as Im "interested" in getting a MIG welder ( although a LOT smaller than what you are wanting) They said."AS A RULE OF THUMB"...take whatever many AMPS of AC a stick welder needs to weld "X" thickness...and figure 3/4's of that for a DC MIG welder. Now that dont mean in ONE PASS...that just means to be able to do the job...if you get my drift. So ..personally..Id figure it would take "some"..."lots".??..more than 75% to get it done in a single pass..
So using that formula..250 amps AC = 188 amps DC...just to be able to do it at all!!
Im not saying this is fact..just what was told to me because I dont know didly squat..other than electic welders USE electric....:)
   / Welder specs #6
I just posted this in a Customization thread....The Lincoln 175HD(pro) at Lowes/HD can handle .45 wire and claims it can handle up to 1/2 plate using gas and proper wire. Maybe someone here that owns one of these can comment. It is the same price as the Miller and Hobart .....$600 or less with a coupon.
RD
   / Welder specs #7
I assume you mean the SP-175 Plus. The Lincoln web site does not list a 175HD Pro so it must be a special label for Lowes/HD, etc.
Anyway, I think you should read the spec sheet VERY carefully. The marketing blurb says it will weld 1/2" with .045 (NOT .45) flux core wire, but when you get down to the nitty gritty charts you will find that it will only do up to 1/4" in a SINGLE PASS and up to 1/2" in MULTIPLE PASSES. This is the same as the Miller MM175 or Hobart models.
It always pays to read the marketing hype with a grain of salt and go right to the actual performance charts for the real information.
The performance chart is on page two of the spec sheet.
http://content.lincolnelectric.com/pdfs/products/literature/e735.pdf
   / Welder specs #8
As a "rule of thumb" does that sort of apply to ALL brands of the 175-180 amp range? Hobart..Miller...Lincoln..etc?
   / Welder specs #9
Amperage and Voltage don't much care what brand of machine produces them.......
Although the bigger names are more likely to give you straighter stories on their machines capabilities.
   / Welder specs #10
MIG welders in the 170-185 amp range are usually only rated for 1/4" for a single pass. Thicker metals will require multiple passes.
If you are going to do 3/8" on a regular basis and want to do it successfully in a single pass then get a 200-225 amp MIG.
If you want to weld 1/2" in a single pass then you need to get something in the 250+ amp range. That is why I upgraded to a MM251.
The biggest difference between brands of the same amp range is duty cycle. The better brand units will have a greater duty cycle. That is usually what you are paying the extra money for.
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2022 Kobelco SK85CS-7 Excavator (A51573)
2022 Kobelco...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
