Welder Generators - Good for house backup power?
   / Welder Generators - Good for house backup power? #1
Knight9
Veteran Member
Alberta
Kubota B2410 with turfs
I've been considering purchasing a generator for backup emergency power for our place. They are not cheap /forums/images/graemlins/blush.gif as I'm sure you all know. Is there any reason not to consider a welder that is also a generator (or a generator that is also a welder) such as the Miller Bobcat 225 ??
In CDN dollars in my area, I can pay less for the Miller and get full welding capabilities, than I would pay for a 10K watt generator. Am I missing something?
Thanks,
Kevin
   / Welder Generators - Good for house backup power? #2
If you really mean emergency then I am sure the welder/generator combo will get it done. If you want all the features of the home genset then I think some will be missing with the combo unti such as the quieter running, hardwire hookup, efficiency, lifespan. But a portable welder is cool.
   / Welder Generators - Good for house backup power? #3
Should work, and I am thinking Gen set too, as well as some thoughts about a welder.
I am wondering about using my CUT as the power (PTO powered genset), to get portability, as well as run a welder. I figure I will likely always maintain the CUT that I have and that may not be the case if the engine powered welder/gen set doens't get used too often.
Field use of a generator might be handy at particular times, and taking the gen set to neighbors in times of downed electric lines might also be an advantage (for them!).
I believe there was a member (Trev?) who a few years ago was into this plan pretty heavy. What happened to Trev?
But interested in what you find out, and will be digging a little deeper into it too. Cheaper to use the CUT engine for power?
Pros and cons.
   / Welder Generators - Good for house backup power? #4
I did the same thing nearly 5 years ago. We had a rare ice storm that knocked out power for several days. I used the opportunity to buy a new Miller Bobcat 225 NT with the Onan engine. They were rated at 8500 watts at that time. I ran a natural gas furnace, refrigerator, freezer, several lights and the TV.
Last week I sold the Bobcat and bought a new Miller Trailblazer 302 with the Onan engine. It's rated at 10,000 watts. I would suggest you buy the Miller Bobcat 250 instead of the 225. The 250 is totally enclosed and much quieter than the 225. My Trailblazer is fully enclosed and I can really tell the difference in noise level.
   / Welder Generators - Good for house backup power? #5
Kevin,
I have thought long and hard on using a generator/welder to power the house. I'm seeing the same price differences as you. I can get a welder/generator for what a good portable generator would cost. Maybe a bit less.
One concern I have with this approach is how much use am I going to get for my dollar? I want to learn to weld but I'm not going to be taking a class for a couple of years at least. My latest idea in the Power Generation Odessy is a DR Mower. Yes a DR Mower. /forums/images/graemlins/grin.gif DR sells a 6000/5500 watt generator that attaches to their mowers. The generator is around $700. Given that I'll be using the brush mower as well as the finish mower at least once a month year round I know I will use what I bought. I really don't want to use the generator but we need one when we loose power.... The DR Mower I am looking at buying has a 17 HP engine. I could provide more power but DR only has one generator.
I did find a couple of companies this weekend that allow you to generate power from you truck. One attached to the engine which I did not like while they other attached to your trannys PTO. Since I have a PTO tranny I could do this. The generator requires engine RPM around 1200 and creates 12KW. Course using a 275HP engine to generate 12KW which can be done with 24HP might not be the best use of the truck engine. /forums/images/graemlins/grin.gif
Later,
Dan
Jesse1,
</font><font color="blue" class="small">( I would suggest you buy the Miller Bobcat 250 instead of the 225. The 250 is totally enclosed and much quieter than the 225. My Trailblazer is fully enclosed and I can really tell the difference in noise level. )</font>
Thanks for the heads up. I'm not sure what the price difference is to move up to the 250, but if it is reasonable I'll keep that in mind.
Kevin
   / Welder Generators - Good for house backup power? #7
If you need or want to weld, the welder/generator combo will be a better value than just a generator. The Miller welders are built for industrial use and they'll last a long time as just generators.
I'd also like to go to school to learn the proper welding techniques but I work shift work and school would be next to impossible now. You can get a lot of useful information on Miller's website www.millerwelds.com under Education. Buy a pound of 6010 rods and start welding on a piece of scrap metal.
   / Welder Generators - Good for house backup power? #8
I use my Miller Bobcat 225 to power a small weekend cabin.
One thing about them though they are loud. I have one with a Kohler engine and wish I had gotten the Onan as they seem quieter.
I have enjoyed using it to weld up my many projects.
Tbar
Tbar,
I checked Miller's site for sound specs. According to the spec sheet, at 7 meters distance, the Bobcat 225 rates 81.5 dB, while the 250 with Kohler rates at 75.5 dB and the 250 with the Robins comes in at 76.5 dB.
I thought I had seen the Onan engine as an option, but apparently not.
Kevin
   / Welder Generators - Good for house backup power? #10
Good evening Kevin. /forums/images/graemlins/grin.gif
I be just a few miles away from you in West Edmonton for a few days visiting my son.
You are having one nice fall.
Egon /forums/images/graemlins/grin.gif
2010 Hitachi ZX450 LC-3 (A42021)
2010 Hitachi ZX450...
HYSTER H135XL2 (A45046)
HYSTER H135XL2...
2016 Freightliner M2 106 Braun Ambulance (A42742)
2016 Freightliner...
2014 Volkswagen Passat Sedan (A42744)
2014 Volkswagen...
W&A 3pt PTO Ditcher (A44500)
W&A 3pt PTO...
New 96in. High Capacity Skidsteer Bucket (A39855)
New 96in. High...
