Welder/Generator adapter pigtail
   / Welder/Generator adapter pigtail #1
gaizy
Mississippi
Kubota L4330
I'm trying to make a pigtail adapter to plug into the 50 amp 250V outlet on my miller bobcat 250 welder/generator so I can use my bobcat to run a 230V mig welder. I connected 10/4 wire from the male adaper (Ground/red/black/white connections) that plugs into my generator to a 250V/50A receptacle that only a connection for a ground and 2 hot wires. Can anyone tell me how to make the correct connections to 250V receptacle? Thanks
   / Welder/Generator adapter pigtail #2
What I've got is Trailblazer and the way I hook up the plasma or suitcase mig to it is with an adaptor I made from stuff right off the shelf at Home Depot.
I used a preformed two twenty fifty amp four prong plug pigtail. It's what you use to hook up an electric stove. I then wired a fifty amp welder's plug receptacle at the loose end of the pigtail.
Keep in mind you have two hots and one ground/neutral on the welder's plug and two hots and a neutral and a ground on the stove plug. So you run the hots to hots and the ground and neutral to the ground/neutral.
Thanks for the explanation but I'm still confused. I did the same thing you did only bought the items from electrical outlet store. Miller wants $100 for their adapter and the parts cost about $30. The 230V/50A welders plug only has 3 places to connect wires; one for ground and one each for red/black hot wires. What do I with the white wire? Thanks
   / Welder/Generator adapter pigtail #4
The white wire is your neutral. You put it with the ground/green wire in the welder receptacle.
Thank you for the explanation and I appreciate your help.
PALLET OF GOLF CART TIRES (A51248)
PALLET OF GOLF...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
12 in Small Excavator Bucket (A52377)
12 in Small...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2013 Morooka MST-2200vd Crawler Carrier (A52384)
2013 Morooka...
