Weld on sprockets
   / Weld on sprockets #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
I have a Mitsubishi BD2f dozer that I had a new undercarriage installed on the unit. The replacements consisted of new rails, rollers and weld on sprockets. The front idler wasn't replaced. The problem is that the tracks come off to the inside. I have had two opinions: The front idler is worn or the weld on sprockets weren't welded properly. Have any of you had this problem? /forums/images/graemlins/confused.gif
   / Weld on sprockets #2
One way to check your sprockets is to jack the machine up an put it on timbers and get a helper to put it in gear and walk one side forward and backwards. then stack a few big blocks next to it and put a dowel or other rough indicator marker on th blocks and secure it neer the hub it should find the high and low spots. My guess is he idlers are worn down or the tension isnt adjusted properly. look at the areas where the idlers touch the rails and look to see if the bushings touching the center of the idler. I usully get tup build these up for a friends land clearing company a few times a year. Hes got doers from a DC4 to a D9G. I just take a my welder and a box of 7018's and weld and chip the flanges of the idlers. I use a light misting of a sprinkler to keep the bearings/bushings in the stub axle of the idler cool. Its tedious but saves a good bit of money.
   / Weld on sprockets #3
Cline adjustments are big reasons to throw tracks.. off center sprocket segments will throw tracks too, as well as positioner idlers..
Soundguy
   / Weld on sprockets #4
I still think you need to shim your front idlers, but here is an authorized Mitsubishi parts dealer who may be able to answer your questions.
We are a authorized Mitsubishi parts distributor and support the dozer, wheel loader and motor grader lines of equipment. If you have any questions or need parts please give us a call.
~Jay
Rhine Equipment Company
800-536-3335
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
Polaris Side by Side (A50324)
Polaris Side by...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
