RJ-NC
I noticed something really strange with the transmission fluid level in my GT2542 today. I normally check the transmission fluid level before each use (while the machine is cold). Today, I forgot to check the level until after driving it around for a few minutes. I was shocked to find that with the machine warm the fluid level was barely at the add mark and looked to have some air bubbles in it. It read full the last time I checked it - about a week ago.
I drove the machine back to storage and started looking for leaks. I couldn’t find any evidence that the machine had leaked on the floor, nor could I see any leakage around the transmission or the filter. After the machine began to cool down I noticed that the fluid level was above the add line but was well below full. I added small amounts of transmission fluid until the dipstick read full. I drove the tractor around for several minutes to get the machine warmed up and checked the transmission fluid level. Again, I found that the level had dropped – not as low as before but still well below full. While the machine was warm, I added fluid until the dipstick showed full. I drove the machine a few more minutes and checked the fluid level again. This time the level remained at the full mark. With the level fixed I decided to mow a bit. After finishing the mow, I decided to check the fluid level again (yep – now I’m paranoid
). Well now the fluid level is well above the full mark and I’m really confused.
Have any of you noted anything like this? Any idea what might cause this type of behavior? I guess I’ll need to drain some of the fluid to get back to the full level since the manual says that running above the full line is bad news. Anyway – I’d appreciate any thoughts on this really strange and unexpected behavior.
Thanks,
RJ
Cub Cadet GT2542 (2006)
Thanks,
RJ
