JDL130
Bronze Member
Last summer I purchased a very nice used JD L130 for a few hundred bucks from the backlot of my local JD dealer. It had just under 300 hours on the clock and aside from a little bit of deck rust was in excellent shape.
I mowed with it for most of last summer at a house we rented after ours sold and before we settled on a new one, and at about 316 hours I had everything together to completely redo it -- deck belt, 5W50 for the transaxle, spark plugs, all relevant filters, etc. So I "overhauled" it at that time, including replacing transaxle fluid, cleaning the magnet, etc. and things worked great.
Fast forward to this summer, new property, more hilly than the rental property which was a dead flat 1 acre. I'm mowing a mostly flat with some hills/slopes 3/4 of an acre now with the rest in pasture/garden/etc. Tractor was great until this past weekend when I noticed a weird "thunk" that would intermittently happen coming from the passenger side rear either in the transaxle or the wheel. It is most pronounced when switching from reverse to forward, but will occasionally happen randomly during prolonged forward drive.
The transaxle has plenty of power and it usually takes about 1 hour to mow the property we have now (lots of broken up yard, trees, around obstacles, etc.) It does not exhibit any slowing of operation during this time and is as peppy going back into the garage at the end as it is coming out to start mowing.
At first it seemed like the deck was hitting something, or perhaps a spindle problem, but I removed deck, checked all spindles, and have been riding around with just the tractor and nothing attached to it and the problem is still there. I don't pull or tow anything with it as I was well aware of the potential weakness of the K46 when I bought it, so it's a dedicated mower. Plus I have a Kubota B1750 for the heavy lifting/tilling/etc.
I replaced the traction drive belt, thinking perhaps the $22 solution might work -- that the original 330-hour belt was slipping and then catching and slamming the trans. It continues to exhibit the problem although less severely. The pulley on the transaxle appears to be OK and not worn down or otherwise compromised.
I removed the wheel on that side and checked the key, axle shaft, etc., and there's nothing amiss. Might be some more play in the hub area than I'd like but I suppose a washer or two would fix that and honestly, the wheels never mounted on really tight with that c-clip setup they have.
Any thoughts? I'm guessing it must be internal to the transmission, I've checked all external linkages, etc., for binding, proper securing with push nuts/cotter pins etc. and can't seem to find anything amiss. Anything I might have overlooked or any thoughts?
I think I can limp it through this season but not really anticipating spending the $$$ for a new tractor anytime soon. Everything seems to have the garbage K46 now (at least everything in a reasonable price range) and I'm not sure it's really worth it to spend @ $1700 on putting a K-66 in this tractor. The idea of throwing another K46 in for $629 (Amazon price) is getting more attractive.
The Kohler 23HP engine is in excellent shape and I'll probably sell it on Ebay if I do end up junking this one, or keeping it.
