Ballast Weights to balance offset implement?
   / Weights to balance offset implement? #1
Winejon
Central Ohio
Recently acquired a used 88" HD flail mower. It's offset to the right. One place I want to use is around a couple of ponds. I would like to attach a weight on the left side of my Kubota M6800 to counter-balance the mower. Anyone know of general purpose (or Kubota-specific) weights for this? I've seen them on roadside maintenance tractors.
   / Weights to balance offset implement? #2
Many of the weights you see off setting the mowers on the roadside mowers are large hydraulic tanks. If I was carrying a 8' offset mower on my tracto I would carry all the front end weight I could and I would probably make a box that hangs of the tractor and loader frames to the left of the left step. The New Holland TN that I have has holes in the frame that the manual shows are for mounting equipment like this. Given a few lengths and weights it would be fairly straight forward to calculate where and what amount of weight you need to carry.
Andy
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
2011 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2011 MACK ELITE...
UNUSED RAYTREE QUICK ATTACH 78" VIBRATING BUCKET (A51244)
UNUSED RAYTREE...
UNUSED AGT QK18R EXCAVATOR (A51243)
UNUSED AGT QK18R...
